Carb refresher - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Carb refresher
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 09-08-2007, 11:25 AM   #1
tony dz
1979 CJ7
Carb refresher
Need a bit of a carb refresher.. It idles about 900-1000 when cold, but after warming iup it idles about 1500-1600. First, I assume this is high, am I right? If so how do I adjust it down? I see reference in my manuals to fast idle adjustment. Is this what I want?
'79 CJ7 that will never be done - 258 I-6, T150, Dana20, Narrow Track AMC20/Dana 30 3.54 w/Trac-Lok, 31 BFG's, Team Rushed
tony dz is offline   Reply With Quote
Unread 09-08-2007, 11:43 AM   #2
kavephish
1981 CJ5
Yes, fast idle adjustment. Does it still idle high after you "kick it down" (tap the accelerator)? If so you should just be able to back the idle adjustment screw off to drop thje RPM's
kavephish is offline   Reply With Quote
Unread 09-08-2007, 11:46 AM   #3
tony dz
1979 CJ7
Thanks.. No it doesn't drop after I kick it down.. What's that point to?
Unread 09-08-2007, 11:50 AM   #4
kavephish
1981 CJ5
most likely idle screw set too high. However, if it just started idling high all of a sudden you might be looking at a carb or vacuum problem.
Unread 09-08-2007, 12:04 PM   #5
tony dz
1979 CJ7
Just noticed my Haynes manual says the "fast idel speed setting" is 1500, which is about where I idle when warm. Just making sure I'm understading this spec correctly. Does this mean I'm OK as is?
1500 still seems high, but I see other models are speced up to 2500. Am I missing somthing?
Unread 09-08-2007, 01:08 PM   #6
Uncle Russ
It's my understanding that your engine should fast-idle until the engine warms up and then it should slow down to the 680-780 rpm spec.
Russ
“When you're swervin' on life's highway, you're runnin' someone off the road."
-- Robert Earl Keen
Military Jeepers Click Here!
Uncle Russ is offline   Reply With Quote
