carb questions - JeepForum.com
post #1 of 3 Old 04-21-2013, 06:15 PM Thread Starter
way2fastmike
1973 CJ5
carb questions
i have a few carb pics and questions.
the pic im pointing at does anyone now what they are and do they need to be hooked up to an thing one iscrimped and the other is just open, both are on the manifold. if i get the video to load it will show the throttle moving back and forth but there is alinkage right behind thats not hooked up ny ideas....
thanks
way2fastmike is offline
post #2 of 3 Old 04-21-2013, 08:22 PM
Ivehad4
1978 CJ7
Pic 3. My Holley has the same annoying and completely unused attachment. Always figured it was for a different style throttle cable setup.
1978 CJ7 304/T150
1959 Willys CJ5 F4/T90
1995 XJ 4.0
1998 TJ 4.0
Ivehad4 is offline
post #3 of 3 Old 04-21-2013, 09:02 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Pict 1: Heat riser for the choke. It should go to a tube which would be under the block off plate below it
This is a Ford setup, but it illustrates what I'm talking about.
2: Direct vacuum port, probably to the EGR or vacuum advance routed through a thermovac switch. I would leave it as is, unless it is leaking vacuum.
3&4: Ford automatic kick down lever. Ford C series transmissions use an aluminum bar from the carb to kick the trans into 2nd for passing. The hole in the linkage is for the adjustment screw.
jeepdaddy2000 is offline
