carb problems? - JeepForum.com
post #1 of 4 Old 06-08-2015, 09:00 PM Thread Starter
johnsskull
1975 CJ5
carb problems?
Hello I'm new to the forum well kinda i was on here years ago.
anyways I have a 75 cj5 304 v8 pretty much stock except headers. so it starts right up and runs great but sometimes I get to a point where i have no power. step on the gas and its like there is nothing there. not sure how to describe there than its like a vapor lock or something. seems like I can get out of the jeep and hit the throttle by hand and it seems fine. has done it to me overtime I get it out now. any suggestions would be greatly appreciated just lost my job and need to get it going to get me back and forth to new job when I find it
things I have done
New fuel pump (manual not electric)
new fuel filter
new accelerator pump diaphragm only
thanks
Johnsskull
johnsskull is offline
post #2 of 4 Old 06-09-2015, 07:33 AM
Mike Romain
Next time it happens, crack open the gas cap to see if it fixes it. A plugged up vent on the tank can cause issues like that.
Mike
Mike Romain is offline
post #3 of 4 Old 06-09-2015, 07:59 AM Thread Starter
johnsskull
1975 CJ5
yes i have tried that one would assume you would hear a realise of pressure but I did not and it did not help.
DOES ANYONE THINK REBUILDING OR REPLACING THE CARB WILL FIX IT?
post #4 of 4 Old 06-09-2015, 08:03 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
If you hear a "whoosh" when you take the fuel cap off, your tank isn't venting properly. Yours sounds like its fine.
Certainly rebuilding the carb is worth a try. It's cheap, and probably needs to be done anyway.
Matt
Matt1981CJ7 is online now
