Carb issue - JeepForum.com
post #1 of 5 Old 07-27-2013, 11:11 PM Thread Starter
sean112280
1997 XJ Cherokee
Carb issue
So I have an Edelbrock 1406 600cfm carb on my SBC. It keeps bogging down. I just changed the fuel filter. What I noticed is there is no fuel coming out of the drivers side jet. How do I fix that?
1974 CJ 5 SBC-SOLD
1997 XJ
XK/WK Owners Group #11
sean112280 is offline
post #2 of 5 Old 07-28-2013, 03:58 AM
I6CJ7
Pull the jet out out and either blow compressed air and or a piece of wire through it to clear whatevers clogging it up.
I6CJ7 is offline
post #3 of 5 Old 07-28-2013, 08:46 AM
WindKnot
1977 CJ7
Carburetor cleaner, yes. Compressed air, yes. Small piece of wire, NO! That jet is calibrated!
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #4 of 5 Old 07-28-2013, 09:16 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Are you talking about the main jet or the accelerator jet? If it is the main jet, you can open the piston cover on the top of the carb, remove the piston/rod/spring and blow some compressed air into the chamber. Observe to see if there is anything coming out of the venturi. If not, then you may have to disassemble the carb to clean it out.
If it is the accelerator pump jet, you will probably want to remove the carb lid to get to the entire system. Be sure you don't lose any check balls.
jeepdaddy2000 is offline
post #5 of 5 Old 07-28-2013, 01:42 PM Thread Starter
sean112280
1997 XJ Cherokee
Thanks guys. I'll have to get into it a lil to figure out the issue. Didn't mess with it to much yesterday
1974 CJ 5 SBC-SOLD
1997 XJ
