Carb ID - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Carb ID
Dan's Old as Dirt Birthday Sale!GEARSHADE Pocket Tops in stock and available at ROCKRIDGE Yukon Ultimate 35 axle kit for c/clip axles with Yukon Zip
Unread 07-21-2014, 11:20 PM   #1
seejayman
I am having some trouble with the engine 258 stalling while rolling without a load on the engine. It will idle fine at startup when stationary and runs well under acceleration. I am having trouble identifying the make of carburetor which makes troubleshooting difficult. Anybody able to help on this one? It only does it when the engine is at temperature also.
seejayman is offline   Reply With Quote
Unread 07-22-2014, 05:49 AM   #2
1949er
Looks like a breed of Weber that's a progressive 2bbl. , there should be a mod. num. on it but you may have to remove it to find it , on my 38 DGAS it is on the base flange by a idle mixture screw .
1949er is offline   Reply With Quote
Unread 07-22-2014, 11:56 AM   #3
carnuck
1984 J-Series Truck
Grab the carb and see if the body or base bolts are loose. If not, cross #1 and #6 plugwires at the cap with the aircleaner lid off and make it backfire a couple times (NOTE: Do NOT do this on Holley or Motorcraft with powervalves or carb rebuild time will come early)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline   Reply With Quote
Unread 07-23-2014, 04:28 PM   #4
uptillnow
uptillnow's Avatar
This looks like that Solex 34-TEIE that had stickers put on it and was sold as a Weber 34-DGEC.
UPTILLNOW
uptillnow is offline   Reply With Quote
Unread 07-25-2014, 06:18 PM   #5
seejayman
Originally Posted by uptillnow
This looks like that Solex 34-TEIE that had stickers put on it and was sold as a Weber 34-DGEC. UPTILLNOW
Think i got it figured out, it is a solex. Seems to be running fine now.
