Carb Help Needed - JeepForum.com
post #1 of 2 Old 04-28-2002, 08:08 PM Thread Starter
MR.CJ-7
Question Carb Help Needed
I have the OEM Motorcraft(2150???) 2 bbl carb on my 304. Normally it starts at the touch of the key(no cranking). Just before I headed down to Moab this past weekend it started acting like it is flooding after I shut off the engine. When I try to start it after a few minutes it is flooded and I must push pedal to the floor to fire it, when it does fire heavy black smoke comes out(if engine is warm). If the engine is cold a whitish-gray smoke comes out(unburned fuel???). No adjustments had been made prior to this happening, except a new fuel line was installed a few weeks ago. It runs fine at highway speeds even up to 80 mph! Gas mileage is higher than ever before, and it performs flawlessly on STEEP climbs. The only problem is the rich smell and my burning eyes from the fumes when rockcrawling. It appears to be worse on the drivers side of the engine than on the passenger side(tail pipe very black and more smoke on driver's side). Could this just be a mixture adjustment or is it time for a rebuild???
Thanks for your advice
Former CJ'er
MR.CJ-7 is offline
post #2 of 2 Old 04-29-2002, 08:38 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
You may have to adjust it, you could e getting more fuel pressure due to the new line, if the old one was leaking. Could also have a stuck float, so it's not responding to the changes in angle, etc. while off-roading. Check those 2 things first, then do a rebuild if you have to. 2-BBLs are pretty simple to rebuild. <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline
Carb ID help needed bluesman423 Jeep CJ Forum 3 05-31-2009 05:15 PM
carb help needed CJfreak Jeep CJ Forum 19 06-13-2008 09:47 AM
Carb Help Needed Hybrid Jeep Jeep CJ Forum 13 12-06-2007 11:48 AM
74 CJ5 with 232...Carb advice needed Orange Juice Jeep CJ Forum 6 04-15-2004 10:40 PM
Carb info needed JoeServo Jeep CJ Forum 2 09-26-2001 02:38 PM
