carb. for a GM 151 - JeepForum.com
 1Likes
  • 1 Post By slacker92104
post #1 of 6 Old 06-24-2007, 12:25 PM Thread Starter
gary c
1981 CJ5
carb. for a GM 151
Does anyone know if a MC 2100 will work on a GM 151 or of any other carb to replace the stock problem causer?
gary c is offline
post #2 of 6 Old 06-24-2007, 05:53 PM
bigjoe
1977 CJ7
What's wrong with the stocker? Why not just rebuild or replace with stocker?
bigjoe is offline
post #3 of 6 Old 06-24-2007, 07:47 PM
Aphelion79
Aphelion79's Avatar
The Rochester that comes on the 151s is a great carb... whats wrong with yours?
1982 CJ7
Iron Duke "Hurricane" 151 CID 2.5L 4-Cyl
T177 Tranny | Dana 300 T-Case
Dana 30 Front | AMC 20 Rear
Aphelion79 is offline
post #4 of 6 Old 06-25-2007, 06:42 AM Thread Starter
gary c
1981 CJ5
possible new carb
I was checking to see if anyone might know of a carb that would work before I got a rebuilt. The PO of my jeep must have used a big hammer to tune it , it's all beat up.
The engine is in good condition except for the carb.
gary c is offline
post #5 of 6 Old 06-25-2007, 01:19 PM
dvbum
1982 CJ5
If your state requires emission inspection for your Jeep. Find a rebuilt Rochester if yours is damaged.
If no emission requirements, stick with Rochester or switch to a Weber http://www.webernorthamerica.com/jp
I have a 82 CJ 5 with the GM 151 with Weber Carb, Clifford Intake manifold, & Hedman Header
Good luck
dvbum is offline
post #6 of 6 Old 06-26-2007, 03:05 PM
slacker92104
slacker92104's Avatar
My little rochester was pretty beat up as well, but after a $15 carb kit and a days work cleaning, it ran like a champ (for a carb) I'd try rebuilding it myself first. If by the po using a hammer to tune it, you mean the chunk that looks to be broken off, someone has already rebuilt it once. You have to break off a plug to get to the mixture screw which was sealed at the factory.
pg_jglr likes this.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
CJ Carb Help please govtmule Jeep CJ Forum 3 10-25-2013 01:05 AM
Carb return line leaking.........too much pressure? And other carb questions. Blthomas Jeep CJ Forum 0 06-01-2009 09:04 PM
Carter Carb Help----Carb Guru's Goody1231979 Jeep CJ Forum 4 04-28-2009 06:03 PM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 05:34 PM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 12:34 PM
