Carb Confusion? - JeepForum.com
post #1 of 1 Old 12-23-2004, 01:57 PM Thread Starter
ollietonk
Carb Confusion?
Sorry to post on a topic that shows up so often but I didn't want to butt in on someone else's thread. I've read all the other posts dealing with the BBD, Motorcraft, and Weber carbs. I've gotten lots of good info but still have some questions.
I have the BBD on a 258 and from what I can tell, it's days are numbered. It starts hard and when running, blows white smoke out the back and STINKS real bad. I've thought about rebuilding it but I was told that it would be "like polishing a turd".
Here's where my confusion starts.
I was interested in doing the Motorcraft conversion. The price looks alot better than the Weber, and another BBD doesn't seem like a step forward. I was talking to a guy last night that said the Motorcraft out performs the Weber and is an easy conversion to make. He also said that the MC would pass the TX emissions test if the EGR and PCV are hooked up. I researched it last night and the conversion is a little more than he said. Looks like an adapter is needed and I'll have to fab a new throttle linkage. I also couldn't tell if the 2100 or 2150 worked better on the 258. Everything I read mentioned the 258 and the 2100, but then it would refer to the 304.
I quess what all this babbling means is: Can the MC be installed fairly easily, does it perform well on the 258 and which one, the 2100 or 2150. Also, can it pass emissions or is my friend on crack. Thanks for any advice.
86' CJ7 (258 w/ Howell TBI, 33" ProComp MT's)
ollietonk is offline
Carb return line leaking.........too much pressure? And other carb questions. Blthomas Jeep CJ Forum 0 06-01-2009 10:04 PM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 06:34 PM
Confusion re. CJ spindrift Jeep CJ Forum 15 05-14-2008 12:44 PM
YF Carb confusion 81CJ7Renegade Jeep CJ Forum 2 11-28-2005 05:16 AM
Weber carb issues...Carb backfiring cjthor Jeep CJ Forum 1 10-15-2004 01:34 PM
