Carb blowing gas ???? - JeepForum.com
post #1 of 3 Old 10-11-2013, 12:59 PM Thread Starter
jamie0921
1973 CJ5
When I turn key gas just runs out this port on top and pours out of cylinders below flappers aswell any idea what this is caused by
jamie0921 is offline
post #2 of 3 Old 10-11-2013, 01:48 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Stuck, or improperly adjusted float.
May be time to rebuild the carb.
Matt
Matt1981CJ7 is online now
post #3 of 3 Old 10-11-2013, 02:12 PM Thread Starter
jamie0921
1973 CJ5
Originally Posted by Matt1981CJ7
Stuck, or improperly adjusted float. May be time to rebuild the carb. Matt
Thank you I just got iit going I pulled the float shook it a bit and blew some gas thru it while I manually raised and lowered floats and seams to work fine now. Someone just put suger in my tank and it must have been a lot because my flaps were glued shut fuel pump shot and floats stuck and I found at least a pound under the intake manifold and in it and I can smell it in the exhaust
