Captured Nut Repair- Frame - Page 2 - JeepForum.com
post #16 of 28 Old 09-22-2011, 12:55 PM
mtnbikeidaho
1982 CJ7
I used a variation of a nutsert called a weld-nut from McMaster-Carr:
http://www.mcmaster.com/#weld-nuts/=e6c3n7
The 1/2" round-base fits right in the original frame hole and provides a 1"+ diameter integral washer to weld to the frame. The new 1/2 bolts would be stronger than stock, too. If you have to re-do, you can grind the welds off and put in another. (Preheating the frame with a MAPP torch helps tremendously with the welding of the different thicknesses - ask me how I know!)
The drawback is the nuts are no longer flush, so I had to shim my crossmember plate with washers on the ones that were still good. Turned out great.
Also, the strength difference in E70 (70ksi) weld vs. mild steel (A36) means you only have to get good penetration on "some" of it for it to stick. (1/8" fillet weld is good for 1600-1800# per inch of weld). Skerr's fix method will hold up forever unless you are a REALLY bad welder...
mtnbikeidaho is offline
post #17 of 28 Old 09-22-2011, 01:40 PM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by Jim1611
Scott something else that needs to be mentioned on this type of repair is making sure the welds penetrate almost completely through the frame. Here's why. The welds need to be ground flat with the bottom of the frame and if the welds don't have proper penetration they may not be strong enough to keep the weight of the transfer case/tranny from pulling the nuts out of the frame. After all they have quite a bity of weight to hold up. A good way to help out here is to grind the outside edges of the nut with a bevel. That way you have more weld in the area around the nut.
What Jim says, is why I didn't mention this in the other thread, I didn't know how thick your frame was, and not much room to weld to on the nut. On the plus side, with 6 bolts holding things up, and approximately 300 pounds total. ( my wag) Its only 50 per bolt.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #18 of 28 Old 09-22-2011, 04:29 PM
82JeepCJ7
1982 CJ7
Great write up.
I had a few bolts twist off or strip out over time. My solution was to drill and tap some 1" wide, 1/2" thick flat bar about 2" long. I got rid of the nut in the frame with a 1" hole saw. I then drilled two 1/2" holes about a 1/2" to either side of the nut hole. I fished the flat bar down in to the frame from one of the many factory holes. Once I got the flat bar into place, I welded around the hole and the two plug welds. Ground it all smooth and painted.
By the way, a wire snake works great for this!
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #19 of 28 Old 09-23-2011, 06:12 PM Thread Starter
Skerr
Sounds like a good fix. How thick is weldable flange on the nutsert?
Bill
Jim's point is a good one. You would definitely have to make good welds. One could leave the nut slightly protruding and weld it in. It would be easier to do, I think.
Originally Posted by 82JeepCJ7 View Post
Great write up.
This also sounds like a good fix. Lots of variations I hadn't thought of...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #20 of 28 Old 09-23-2011, 09:09 PM
mtnbikeidaho
1982 CJ7
It's about this thick: 3/32" to 1/8" for the 1/2"-13 size
post #21 of 28 Old 10-03-2011, 05:56 PM
Bojon
1981 CJ5
Great write up!! I used this this afternoon with one addition. I drilled some holes around the nut to increase the weld strength. Just don't do what I did, you can kinda see in the second picture where I got a little hammer happy and bent the frame inwards. oops
Jered
Bojon is offline
post #22 of 28 Old 10-03-2011, 06:24 PM Thread Starter
Skerr
Beautiful job, Jered! Thanks for posting that up. And good idea about the additional holes.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #23 of 28 Old 10-03-2011, 09:48 PM
GlennLever
GlennLever's Avatar
Nice post, I might have to do this.
I broke this nut off when removing the power steering gear box.
I have not gotten back to it yet to try and remove it.
I have been soaking it with PB Blaster.
This weekend I will hit the frame around it with some heat and then water to try an break the rust, and then cross my fingers and try and turn it out with vise grips. If that does not work I will grind it flush and drill and tap. If that doesn't work I will use your method.
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #24 of 28 Old 10-03-2011, 10:12 PM
80cj
80cj's Avatar
1980 CJ5
I know a guy that just got a piece of 1/2" x 1 1/2" flat stock, drilled and tapped holes in it and welded it to the bottom of the frame. Worked out fine for him since he had his skid plate shimmed down anyway to correct U joint angles.
80cj is offline
post #25 of 28 Old 10-04-2011, 04:19 PM Thread Starter
Skerr
Bob, that makes perfect sense and would probably have been a smart fix in my case... but I thought of it after the fact. I'm slow that way! You should have told me before I had to do it!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #26 of 28 Old 10-04-2011, 05:44 PM
hp_lovecraft
1981 CJ5
Don't feel bad. I stripped out 2 nuts on my skidplate last year, and my solution was to drill them out, and then drill a matching hole on the TOP of the frame.
So I then use a huge bolt (6"?) that goes completely through the frame, so I can use a nut on the top.
It occurred to me that this is going to stress the frame in weird ways, and its going to make any crack bigger..... but reading this thread makes me realize I should have welded in a new nut. That weldable nutsert looks like the easiest way?
hp_lovecraft is offline
post #27 of 28 Old 10-04-2011, 10:29 PM Thread Starter
Skerr
I have to agree the nutsert looks like a mightly convenient way to fix it. It's not too late for you to make that repair!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #28 of 28 Old 04-30-2015, 11:39 AM
StoneTower
I have done similar things with a piece of flat bar. If you want to capture more than one bolt hole, you drill and tap all the holes in the flat bar and then insert it in the frame, Having drilled a couple of holes to plug weld it in, center it up with a couple of bolts and then burn it in. It becomes a captured nut that is much stronger than the factory because it is longer and tied in more than one place. There is no danger of the nut pulling through the frame as in some of the other weld in nut repairs.
On another note...if you are going to repair the frame as the guy did above with the three holes drilled around the hole where the nut is inserted, you could just drill the three holes in line to create a slot and then insert a square plate with a threaded hole in it. You could then weld that in. There would be little danger of it pulling out. You would have a recessed thread and would have to weld to the side of the threads.
StoneTower is offline
frame repair ? nattylite Jeep CJ Forum 7 09-22-2009 10:09 AM
Frame Repair - cutting frame open to remove rust? Bell-Vegas Jeep CJ Forum 4 04-21-2009 10:44 PM
Frame repair Tsjellum Jeep CJ Forum 4 08-30-2007 06:24 PM
Frame repair ? mpwal099 Jeep CJ Forum 7 03-02-2007 08:16 AM
Frame repair mudrunninCJ-5 Jeep CJ Forum 5 10-18-2004 07:35 AM
