Captured Nut Repair- Frame - JeepForum.com
post #1 of 28 Old 09-21-2011, 01:56 PM Thread Starter
Skerr
I had to replace a couple of captured nuts on my fame for the transmission crossmember. I showed this in my build thread, but it's been many pages ago! I thought I would do a thread in case anyone was interested. This process works very well and eliminates the need to cut a hole in your frame. It's easy and you don't need a lot of experience to be successful. In this demo I was on my creeper looking up. The hardest part for me was overhead welding! Just take your time, be GENTLE, and it will come out great.
I hope this is useful to somebody.
These two nuts are stripped. I stripped them out while torquing them after reinstalling my crossmember. Glad it happened now! These are the two closest to the front spring hanger at the rearend.
Grind off the old paint.
I'm using the stripped factory nut to hold this bolt with the new nut in place.
Using a Sharpie, mark the lobes of the new nut.
Remove the bolt and nut... this is what you have.
I had to sharpen my chisel! Notch the hole at each lobe. The factory nuts broke out while notching.
After notching the lobes.
I tried to use my air chisel, but it didn't work for me. If you try this, go slow! Don't cut TOO much.
Hold the new nut in place. The bolt is nothing more than a handle at this point.
Using my shop hammer (3#) I carefully beat the nut into the notched hole. You can sort of "feel " the nut as it countersinks. Be careful NOT to knock the nut into the frame. If you do that, unscrew the bolt and get another nut!
The new nut is countersunk to the desired depth.
Leave the bolt in place while welding to protect the nut threads. You will probably have to clean the threads with a tap when you finish.
Welded and ground down.
Primed
Painted and done. When paint dries I can bolt my crossmember back up. The whole thing took me about an hour and a half.
I hope this is helpful to somebody! Good luck. PM me if you have questions.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2 of 28 Old 09-21-2011, 02:11 PM
FLynes
FLynes's Avatar
1976 CJ5
Great write up, Scott! I know I have some bolts missing from my crossmember, so now that the powerplant and tranny are out, I can crawl under and look to see what kind of mess I have and use your thread to redo mine, if needed.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #3 of 28 Old 09-21-2011, 02:18 PM
Jim1611
Jim1611's Avatar
Hey if you put a flat washer in bewteen the nuts you don't have to worry about driving it in too far.
That turned out really nice.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #4 of 28 Old 09-21-2011, 02:23 PM
CJ7ROB
Yea this is good. I need to do this for one of mine, except the nut just spins in the frame so I had to cut the bolt head off.
CJ7ROB is offline
post #5 of 28 Old 09-21-2011, 02:24 PM Thread Starter
Skerr
Thanks, Fred. If you can do the repair from above it will be eaiser. Don't know if your frame is stripped down that far yet.
That's a GREAT idea, Jim. It would set the nut at the correct depth. Hadn't thought to do that.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #6 of 28 Old 09-21-2011, 02:35 PM
FLynes
FLynes's Avatar
1976 CJ5
It's getting there...I've had long work days this week and just haven't felt like doing much. I still need to finish taking the short block apart, so I can hot tank the engine and mike it to figure out how much I need to hone or bore. The frame is still rolling, for the moment, but I want to take the axles out this weekend and put it on jackstands. If there any repairs to be made, it would make sense to do them, before I get it blasted.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #7 of 28 Old 09-21-2011, 03:36 PM Thread Starter
Skerr
Rob, in your case, since you don't have the factory nut to hold the bolt, you will need to hold the nut in place with the bolt, then mark the lobes.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #8 of 28 Old 09-21-2011, 04:25 PM
agear
I think I gotta couple loose nuts(captured). I'm might be able to use this
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #9 of 28 Old 09-21-2011, 04:48 PM
MoC
Great job Scott!!
ps - Really enjoyed talking with you the other day!
MoC is offline
post #10 of 28 Old 09-21-2011, 05:29 PM
Jim1611
Jim1611's Avatar
Scott something else that needs to be mentioned on this type of repair is making sure the welds penetrate almost completely through the frame. Here's why. The welds need to be ground flat with the bottom of the frame and if the welds don't have proper penetration they may not be strong enough to keep the weight of the transfer case/tranny from pulling the nuts out of the frame. After all they have quite a bity of weight to hold up. A good way to help out here is to grind the outside edges of the nut with a bevel. That way you have more weld in the area around the nut.
My build thread
Jim1611 is offline
post #11 of 28 Old 09-21-2011, 06:47 PM
Splinter
1980 CJ5
That would be exactly my worry. Me being a self taught welder trying to get good penetration on a overhead weld. What if one welded pieces of 1/2 inch flat bar down the side of the frame and across the bottom and then tapped new holes. I could probably do a decent job of this. This would drop the tranny an additional 1/2 but is that a big deal?
Splinter is offline
post #12 of 28 Old 09-21-2011, 07:38 PM
Galt
Galt's Avatar
1983 CJ7
Nice job.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #13 of 28 Old 09-22-2011, 12:36 PM
scrappycj5
1976 CJ5
This is a great Idea, as long as you get good penatration in the frame. As mentioned before, it is holding up pretty much the tcase,tranny and somewhat the motor. If the welds break, it would be a mess.
Not trying to steel the thread, but has anyone tried nutserts ? They have some that actually would spread on the inside of the frame and be pretty much perminent. They also have ones that would spread inside the frame as you tighten, but would retract as you loosen. I was thinking of trying them but got impatient and just welded a coulple pcs of angle iron to my crossmember, then thru bolting them thru the frame. I am not restoring mine, so I wasnt looking for pretty.
scrappycj5 is offline
post #14 of 28 Old 09-22-2011, 12:51 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I had asked the local bolt and nut house about nutserts, because I was trying to figure out how to bolt the rear of a winch plate down when it comes time for that. He said they are aluminum, so they wouldn't be a good idea for a winch plate - they'd probably pull right out. Are there any that aren't aluminum?
Rick
Cutlass327 is offline
post #15 of 28 Old 09-22-2011, 12:54 PM
WNC-84CJ7
cr@p. I hope I don't have to do this. Looks great Scott!
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline
frame repair ? nattylite Jeep CJ Forum 7 09-22-2009 11:09 AM
Frame Repair - cutting frame open to remove rust? Bell-Vegas Jeep CJ Forum 4 04-21-2009 11:44 PM
Frame repair Tsjellum Jeep CJ Forum 4 08-30-2007 07:24 PM
Frame repair ? mpwal099 Jeep CJ Forum 7 03-02-2007 09:16 AM
Frame repair mudrunninCJ-5 Jeep CJ Forum 5 10-18-2004 08:35 AM
