Cant Remove Body Mount Bolts - JeepForum.com
post #1 of 5 Old 07-18-2009, 08:09 PM Thread Starter
Cowtown76CJ5
1976 CJ5
All of the nuts that are supposed to be connected to the frame are breaking off before I can loosen the bolts. Will I have any major issues if I just cut the bolts?
It's only money!
Cowtown76CJ5 is offline
post #2 of 5 Old 07-18-2009, 08:30 PM
tonsoffun_77
1977 CJ5
might try some pb blaster to spray on them...might help
'77 cj5 renegade 304 V8 3 speed
tonsoffun_77 is offline
post #3 of 5 Old 07-18-2009, 08:34 PM
gojeepin
1983 CJ7
They're breaking off? Are they spinning in the body?
They're not really nuts, just 1" squares of steel that are drilled and tapped.
Are you going to just replace the body mounts? If you're going to have the body off for a while, you can cut the bolts if you're willing to cut the body open to remove the old "nuts" and replace them.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 5 Old 07-18-2009, 08:47 PM Thread Starter
Cowtown76CJ5
1976 CJ5
Yea, they are spinning in the body. The body is coming off to try and replace the front crossmember. Every time I remove a part from under the tub, I get a hand full of beach sand. Once I get the body off, I will decide if it is worth repairing. To replace the old nuts, do I just weld in new (actual) nuts?
It's only money!
post #5 of 5 Old 07-19-2009, 10:41 PM
smokedog
Having same problem and we decided to flip tub on it's side. Leave the bolt in and clean area around the base. Next hold bolt with channel locks and center it while pulling it firmly towards you. Next weld it tight. Now you can remove the bolt and you didn't have to cut into the channels under your tub. Hope this helps.
Smokedog - Brandon, MS
84' CJ7 Renegade - Tungsten grey metallic paint, 388ci Chevy, 700r4, D300, SOA lift with YJ springs, 1" body lift, Bilstein 5150 shocks, Currie Rock Crawler Shackles, Trussed Ford 9 Rear w/ 4:56 gears, Detroit lockers, Dana 44 front, full poison spyder cage and lots of chrome and stainless.
smokedog is offline
Body Mount Bolts Redmanchew Jeep CJ Forum 4 08-14-2011 03:17 PM
Need new body mount bolts. HELP jatepper Jeep CJ Forum 4 07-19-2007 12:21 PM
Rear body mount bolts on a 78 CJ5 ETJeep Jeep CJ Forum 3 06-22-2007 09:08 AM
Removing body mount bolts ETJeep Jeep CJ Forum 1 02-10-2007 07:41 AM
Body Mount Bolts... collinpyle Jeep CJ Forum 3 10-02-2006 03:59 PM
