Can't push rolling chassis? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Can't push rolling chassis?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFord Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip Elim07-15 jeep JK Spare Tire Carrier Delete Plate
Unread 05-30-2012, 09:30 AM   #1
Kastraelie
1977 CJ7
This one is stumping me...
I have my CJ7 tore down to just the frame, suspension, and axles.
Since the parking brake cable does not connect to anything anymore, I don't think that is the issue... I do have the powersteering system hooked up.
Anyways, I can push the darn thing backwards and it rolls OK, but forwards is a no go. The weird thing is when I try to push it forwards the back passenger side wheel locks up and just drags the tire. If I PUSH that tire, rotating it like a giant captains wheel, I can move the chassis forwards...like the diff stops seizing or something.
I could push my fully built YJ in neutral around all day long and moving this chassis is like pushing a grounded oil tanker...
Anyone want to explain to me what noobie mistake I am making? I would have posted this in my build thread but answers are slow in there.
Thanks so much!
Kastraelie is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 09:33 AM   #2
MightyLampshade
1979 CJ7
I'm taking a wild stab here but is it possible there is a locker in the rear axle? I'm not even sure if that would cause the behavior you're describing but I'd be tempted to take off that diff cover and see what was going on inside there.
Originally Posted by Keith
Let's make fun of him for being assaulted by chicken so he can claim emotional distress.
1979 Golden Eagle Rebuild
MightyLampshade is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 09:46 AM   #3
mopar346
Is the pinion loose by chance? It can walk in and bind against the case.
Do you have 2 different ratios fron and rear and the T-case in 4WD?
Is it possible soem of the brake hardware is loose in that wheel?
Did it sit with the parking brake engaged for an extended period of time?
Are the brakes adjusted too tight on that wheel?
That is all I can rattle off quickly, the locker shouldn't matter unless you are turning it, if it is when turning then I agree or check for a spool.
Careful your character's showing
mopar346 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 09:53 AM   #4
Kastraelie
1977 CJ7
Hmmm some good things to check here.
Unfortunately I don't have alot of answers as I know next to nothing about this frankenjeep's history. I know that the T case isn't in the vehicle or the driveshafts, so I can rule that out. The parking brake might have been engaged for a long arse time, but I did release it when I took the vehicle apart...I think. xD
The solution for most of them is to get in there and take it apart more...which is fine because that is what I need to do at this point.
Thanks for the ideas guys, Mightylampshade and Mopar.
Unread 05-30-2012, 09:53 AM   #5
CSP
You have a brake shoe binding with the drum. Try to drive a drum brake vehicle with the emergency brake on. It will go backwards, but try to go forward and it won't move.
Same thing here.
CSP is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 09:54 AM   #6
Kastraelie
1977 CJ7
Same thing here.
Ok awesome, that sounds like it might be it. Thanks!
Unread 05-30-2012, 11:05 AM   #7
mopar408
1974 CJ5
Just to check that it IS brakes and only that 1 wheel, pull the one wheel, remove the drum and reinstall wheel.
If it rolls good you have brakes to troubleshoot.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 11:10 AM   #8
mopar346
Chances are he is gonna have a time getting the drum off.
Make sure the brake cable is fully released (the wheel that goes to that wheel) and back the brake adjuster way off. If the springs are broken in there it can act that way as well, goes to what CSP is saying, shoe floats and binds.
Unread 05-30-2012, 11:40 AM   #9
mopar408
1974 CJ5
Das' right and in itself will tell him that it's brakes. On the other hand, it's also a good chance when he pulls the drum the whole $#!+ will just pour out and explain why it bound up.
Unread 05-30-2012, 11:44 AM   #10
mopar346
Sounds like experience talking there.
You're among good company.
