-   -   This can't be normal, right? (http://www.jeepforum.com/forum/f8/cant-normal-right-1345156/)
pagnani 03-19-2012 12:42 PM
Hello all,
I am new to JF and very new to owning a Jeep. I purchased an 83 CJ7 in December. I do not know a ton about cars but am willing to get in and figure things out if I have a little bit of direction. I know you guys will ask me to fill out the info about my CJ but I am unsure how to tell what I have. PO basically took my $1000 and handed me the keys and tittle.
The issue I have is that it is a little rough to start in the mornings. My initial thought is that it's not a huge deal since it's 30 years old, but my issue is the black specks all over the floor near the exhaust. I let her warm up for about 10 minutes in the morning and when I am ready to drive off there is quite the spray of black specs coming out of the exhaust. This pic will hopefully show what I am talking about
pagnani 03-19-2012 12:44 PM
https://lh3.googleusercontent.com/-n...1-k/12%2B-%2B1
Palmetto 03-19-2012 12:48 PM
My guess (and I am not a guru, just an amateur) is that the specs are oil.
Seems like it may be worn rings (piston rings) allowing oil to blow by and exit through the valves
and then the exhaust.
I'm sure more seasoned individuals will give you additional info.
Dngrs1 03-19-2012 12:54 PM
An entirely new exhaust system will take care of that, until the carbon builds up in the new pipes. :rolleyes: Seriously, as you live in Utah, where it is probably freezing at night and warmer in the day, condensation will form in the pipes and soften the built up carbon in the pipes and then be blown out when the engine is started. The hard starting could be a number of things. I would start with ensuring the choke is working properly.
Oh, Welcome to the Forum!
WindKnot 03-19-2012 12:59 PM
Does it eventually dry? If it does, my guess is that the Jeep is running rich and the black fuel smoke is mixing with the condensation.
Normal? As in do a lot of Jeeps do this? Yes. Should they? No, not really. There could be all kinds of reasons why the Jeep is running rich, from just a badly tuned carb to compensating for a lousy choke to something more serious.
Welcome to the monkeyhouse, by the way. Post up in your profile what you do know. As you read more you will learn how to figure out some of the blanks and can update as you go.
In the meantime, check your oil consumption and you might want to do a compression check. The numbers should be within about 10% of each other down the cylinders.
Ken4444 03-19-2012 01:02 PM
929 Attachment(s)
Can you provide specific details about the hard starting and what specifically you're having to do to get it running?
..when I am ready to drive off there is quite the spray of black specs coming out of the exhaust.
Postion a paper towel over the exhaust pipe to catch the black specs. Once the towel is really dirty, put it in a bucket of clean water and squeeze it out and see if any oil floats to the surface after the water settles.
iDriveYJ 03-19-2012 01:05 PM
x2
DaddysCJ 03-19-2012 01:08 PM
Mine does the same thing. If you'll look in the "new guy" post I just submitted, you can see the black infront of LR tire. Thats were my pipes dump. Mine has gutted glasspacks on it I think that will be replaced soon. (way too loud for my wife) I hope its the exhaust system like 1979CJ said.
pagnani 03-19-2012 01:08 PM
Hard to start
Basically with any older car, I assume there is a ritual. Turn key to on, pump gas a time or two, try to start, after 5 seconds let off, wait a second or two, pump again then try to start. This goes on for about 30 seconds, depending on how cold it is.
I did change the oil, cleaned the air filter, as far as carbs go, I have no idea how to adjust them. I will upload a picture after lunch so you can see what I have. I know it's aftermarket.
248107 03-19-2012 06:18 PM
Welcome aboard.
Provo Utah ,IRS capital of the world.
Like said fill out the profile and tell what kind of carb you have or description. 6 or 8. and the members will get you going and steer you in the right direction
CJ7Sasquatch 03-19-2012 06:31 PM
Mine does the same thing, just condensation sling with maybe a tad bit rich on the choke, no big worries in my op
wellmax 03-19-2012 06:50 PM
install a new set of autolite plugs
hard start issue: Fuel Filter
fuel filter must be positioned with one pipe in and two out (the outside out pipe must be positioned on top as it goes to the vac canister, the center out pipe goes to the carb.
if the fuel filter is not positioned in this manner, when you stop the engine the fuel can be syphoned out of the carb and back into the fuel tank,
this will cause you a slow hard start next time, as your fuel pump must replace all the fuel that flowed back to carb before jeep will start..
check position of fuel filter and let us know what you find!!!!!!!
at night in a very dark place open the hood with motor running and look at your sparkplug wires, do you see any fire, if so you need new wires.
all these little things add up to slow starts, poor mpg and performance.
what type air filter and what is its condition?
if you have any doubt about the air filter, get a new one, pvc valve and fuel filter.
battery must also be in top conditon to spin the old jeep,
send us a few pictures of your new toy!!
Trapshooter 03-19-2012 06:54 PM
First.....Welcome to the Jeep Forum and the CJ family, tons of good stuff here for your new rig.
A couple of pics of your engine, one from either side, would be helpful. Your cold starting issue could be something as simple as a fuel filter not clock properly and draining the carb bowl of fuel.
Good Luck.........
The time now is 08:55 PM.
