Can't Get To My Zerks - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Can't Get To My Zerks
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 08-10-2013, 04:33 PM   #16
agear
There is this fitting too. It gets from the side. or if you can remove the fitting you can switch to a different style even if you can only put it in just for regreasing then remove it. Can you get on the fitting much at all with the grease gun -sometimes you gotta try it a few times and hold it pressed on pretty good to get it to grease.
disreguard the 2nd photo.
.jpg
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline   Reply With Quote Quick reply to this message
Unread 08-10-2013, 09:16 PM   #17
shelldrake
Dropped the drive shaft today, fixed the broken zerk and greased both of them. Next time, I will try the needle.
Thanks again for all the help.
shelldrake is offline   Reply With Quote Quick reply to this message
