#1 | |
Can't get bolt out of leaf spring
Any tips on how to get it out. I have sprayed it with PB blaster, tried to unbolt it, hammer it. I am lost. Any tips would be awesome. Here is one of them I am dealing with. Have 3 to get out. Thanks
#2 |
have you tried a sledge hammer? I would probably cut the bolt and just pound on it until something broke.
1989 Jeep Comanche MJ: 2WD, 4.0L, BA-10, D30, D35, 4" IRO Front, SOA Rear, Winch Bumper, Trimmed Fenders/ Bed. Working on 2wd->4x4 Conversation. My Build: http://www.jeepforum.com/forum/f22/my-slow-build-89-jeep-mj-off-road-hunting-rig-pic-heavy-1268973/ |
#3 |
No, haven't tried sledge hammer approach. I cut one of them and though it would make it easier but no luck. It is starting to mushroom the bolt. And also, I don't have a sledge hammer or torch, anything fancy. I am a broke college student.
#4 |
Try heating the leaf spring with a propane torch. after the spring is hot hit the bolt out with a drive pin and decent sized hammer.
Your ghetto sled is my speed bump! BNB #156 |
#5 |
I don't have a torch, I might be able to track one down but I was hoping for another solution. I will start trying to track one down, thanks. Any other tips or ideas.
#6 |
X2 on the sledge hammer!
#7 |
Don't heat it unless you want to ruin the spring. Have someone press it out with a hyydraulic press.
#8 |
is is the rubber bushing you are trying to replace? If you have no heat (I;d get a hand held torch, you'll need it) you can take a thin drill bit and drill outthe rubber so the bolt/sleeve that is rusted together will come out, and the replace the bolt.
Sawzall the bolt off and do the same for the bushing. Either way, i'd replace the bolt and bushing, it's easier than trying to get it out. |
#9 |
#10 |
Haha well once again, broke college student.
![]() I just posted on my local 4x4 board to try to get some help with this as I am limited when it comes to tools. |
#11 |
Junior Member
Hey tried wd40 pb blaster is a penetrant not a lubricant spray with wd40 and turn bolt as you are spraying it if you feel it geting loose turn it and hit it at the same time.it wasn't forced in and shouldn't have to be froced out.
#12 |
just throw a party and say first one to get the bolts out gets a case of beer.
#13 |
Maybe you could rent something like this from your local rental joint.
- Harbor Freight Tools - Quality Tools at the Lowest Prices FT
1980 CJ5 39k Dana 30--AMC20--D300--T176--258 1986 CJ7 Dana 30--AMC20--D300--T5--2.5L |
#14 |
Lost and Not Found
Drill the bushing out around the bolt. It will take multiple holes around the perimeter of the bolt. That should give you room to beat it out. If it's a factory bushing then it should be easy to drill. Just make sure you have the spring laying on something solid when you hit the bolt.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage It's easier to get forgiveness than permision. Salad is what food eats!!! http://emptypocketsoffroad.org/ |
#15 |
ALSO, find a way to secure the spring so it isn;t moving. Secure it close to the spring eye so when you "whack" it, most of the force isn;t absorbed by the spring moving.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
