Can you change body bushings without removing the body? - JeepForum.com
post #1 of 10 Old 06-10-2013, 03:27 PM Thread Starter
M20Keeper
1982 CJ7
So that's the question, can you replace the the bushings without removing the tub?
M20Keeper is offline
post #2 of 10 Old 06-10-2013, 03:39 PM
LeePrather
1978 CJ5
Yes. Enjoy getting all the old ones loose and out though. If any are rusted, you are probably gonna end up cutting. I did all mine with the tub on, you can take the bolts out on one side and jack up the tub off the frame, change them out and lock them back down. Go to the other side and repeat. Took me about 2 days because I had to cut to get to the nuts in the frame that were spinning
LeePrather is offline
post #3 of 10 Old 06-10-2013, 06:23 PM
Gigemags05
1980 CJ7
Exactly what the above poster said. It was one of the biggest beatings I've taken with this jeep. They are all incredibly difficult to cut out, and you will almost certainly have to cut them out. I put kroil and pb blaster on them for over a week straight and still broke all but a couple when I tried to back the nuts off the bolts. Ended up having to weld up a few new mounts and had to drill a couple of holes on the floor board to reach a couple of them.
Made a HUGE difference in the ride quality, though, and was inexpensive, albeit time consuming.
Gigemags05 is offline
post #4 of 10 Old 06-10-2013, 07:17 PM
LeePrather
1978 CJ5
Lol I left "access panels" in case I need to go through that again!
post #5 of 10 Old 06-11-2013, 07:50 AM
WindKnot
1977 CJ7
DON'T USE AN IMPACT WRENCH! The retainer nuts are held by small tabs and if you continuously beat on them they will fail. A big cheater will establish contact with the tab only once and will apply constant pressure against them and they will hold the nut better. Don't be surprised if some welding is needed to repair rust.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #6 of 10 Old 06-11-2013, 02:39 PM Thread Starter
M20Keeper
1982 CJ7
I am beginning to weep now....
post #7 of 10 Old 06-11-2013, 02:46 PM
82JeepCJ7
1982 CJ7
Invest in PB Nutbuster...
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #8 of 10 Old 06-11-2013, 02:47 PM
Gigemags05
1980 CJ7
At least you can do it without removing the tub, haha.
Also, it doesn't take much skill, just a lot of sweat. You'll feel great about yourself when it's done.
post #9 of 10 Old 06-11-2013, 03:01 PM
LeePrather
1978 CJ5
It really isn't that bad. I spent most of my time finding something to get out the bolts (like usual) and finding (buying) the right tools. I ended up with a new dremel tool in the deal. Just an FYI, the tops of these bushings have a small metal plate over them that are supposed to keep the nut inside them from turning so you can just put a wrench on the bottom and voila! (Not to get your hopes up, but that isn't what happens). Those metal plates have to be removed in very small spaces if you want access to the nuts. There is little to zero access to the top side of these bushings except in 2 of the 11. I had to cut small pieces from the frame to put vice grips on to keep the nut from spinning in 7 of my 11 total. Replace the bolts, washers and nuts if you can when you are in there and just consider how you can make a future bushing change easier when you are in there. (I think Fred Flintstone was the engineer on this part)
post #10 of 10 Old 06-11-2013, 03:58 PM
spward
I guess I was lucky. I managed to only have 1 spin on me and I was able to us an impact wrench on all of them. The one that spun was right below the fuel filler and I was able to peel the sheet metal back and wedge a cold chisel in there to stop it from spinning. Hope all goes back together easy.
Scott
spward is offline
