Can't stay low enough. ??? - JeepForum.com
post #1 of 11 Old 11-22-2013, 06:59 PM Thread Starter
tdkask
I have an unusual problem in the Jeep world... I don't want my Jeep any higher than it sits.
I have 4" lift springs and am running 33's ATM. I intend to go to 37's as soon as I install my HPD44/Ford 9" combo, and have an issue.
Basically, the D44 is trussed and therefor has about 2" extra material above tube at frame. I don't want to go to more lift or longer shackles or anything, and definitely don't want to go SOA... way too much lift even if I go to stock YJ springs. I will run a high line fender/hood combo, and don't need more lift to get to 37's and not rub. I hope to go 4" up travel and 6" down travel and keep my COG where it is now. My problem is that at 4" up travel the truss will meet the frame. I'm looking for suggestions. Right now I only have thought of notching frame or ditching truss or add lift.
Any ideas or input, especially pictures, would be appreciated. Thanks.
here is the truss that has been pieced on.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #2 of 11 Old 11-22-2013, 08:04 PM
brownbagg
1930 MK Compass
cut the fenders. get flat fenders for front and those metal panels for rear
brownbagg is offline
post #3 of 11 Old 11-22-2013, 08:52 PM
twinstickd20
1979 CJ7
Cut the truss down or even build a new lower profile one.
My Build Thread
twinstickd20 is offline
post #4 of 11 Old 11-22-2013, 08:57 PM
CSP
Ditch the box tubing and build a truss that conforms better to the axle's natural shape.
Unless you're getting airborne there's really no need for a truss to begin with.
CSP is offline
post #5 of 11 Old 11-22-2013, 10:10 PM
JRPettet
1980 CJ7
Agreed,
Ditch the truss. If you are serious about good suspension travel and low center of gravity you will have to modify the frame.
JRPettet is offline
post #6 of 11 Old 11-22-2013, 10:11 PM Thread Starter
tdkask
I do bounce it off a hill or two every once in a while.
I want a truss, and don't know if I can cut it down much and still have a truss since the diff is so close to the frame.
I am considering notching and re-enforcing the frame above the axle.
Cutting the fenders more (and I will be) won't change the clearance between axle and frame.
If I run 10" shocks and get 4" up and 6" down I'll be good, but will only have max 4" between axle and frame as it is right now.
tdkask is offline
post #7 of 11 Old 11-22-2013, 10:27 PM Thread Starter
tdkask
I just went and measured everything out again. At ride height there will be approximately 4.5" between truss and frame. Basically, I'd have no room for bump stops to protect the shocks, really. I may be able to bump stop outside frame easily enough. Shocks will be on hoops, so maybe have enough room, especially with the full width axles.
tdkask is offline
post #8 of 11 Old 11-23-2013, 09:09 AM
JeepHammer
Running On Empty...
1973 CJ5
I don't think that's unusual...
The lower the center of gravity, the better the vehicle goes down the road and trail...
Normally, you will need about 4" above axle to frame contact (BUMPSTOP!) without bottoming out the shocks.
Bottoming out shocks is the easiest way to ruin/break shocks I know of, so use bumpstops to keep that from happening.
DROOP is the big deal, and limiting straps to keep shocks from overextending is a priority if you don't have leaf springs to do that...
I have to agree, if you have really large tires with moderate or no lift, then cutting the fenders is about the only way to keep tires out of body...
You *CAN* notch the frame for your trusses, but you will have to be VERY CAREFUL about reinforcing the area once you cut into the frame... And in the front I would think clearing the oil pan would be an issue, so bump stops become critical again...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #9 of 11 Old 11-23-2013, 05:24 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Gotta agree with CSP with the "ditch it or cut it down" recommendation. I don't think the benefit of that tall truss outweighs the downside of hacking into the frame.
A front D44 axle will take quite a bit of abuse without bending... certainly some moderate bouncing. You'd be more likely to destroy a hub or break a shaft/ujoint before bending the axle housing.
BESRK is offline
post #10 of 11 Old 11-23-2013, 05:25 PM
MoC
Originally Posted by besrk
gotta agree with csp with the "ditch it or cut it down" recommendation. I don't think the benefit of that tall truss outweighs the downside of hacking into the frame. A front d44 axle will take quite a bit of abuse without bending... Certainly some moderate bouncing. You'd be more likely to destroy a hub or break a shaft/ujoint before bending the axle housing.
x3
MoC is offline
post #11 of 11 Old 11-23-2013, 08:02 PM Thread Starter
tdkask
I think maybe I'll drop 1" out of the truss at that point and MAYBE notch 1/2" into frame, then put in a 2" rubber block for bump stop. Or maybe suck it up and go with 1/2" more lift. I'm going to put the perch as close to the tube as possible and still clearance the leaf center pin bolt. My long side tube is 1/2" tube, short side is just 1/4", thus the reason for the truss. I'm sure this axle will hold 37's as well as my LP D30 holds 33's.
tdkask is offline
