Can't shift into first - JeepForum.com
post #1 of 9 Old 09-30-2013, 11:30 PM Thread Starter
Jsdtm
Hi all, hopefully someone can identify what I am experiencing. I am about 2 months into my " new " CJ and am curious about my shifter issue. I've tried to look at other threads but haven't found anything that matches. I have an 86 CJ 7 i6 automatic transmission 3 speed with the shifter on the steering wheel. All the gears on the shifter works besides first. I can't move the shifter all the way to the first position in other words. All the gears run through fine when in drive, I can manually shift into second but can't manually go to first. It's like there isn't a first position on the shifter. Anyone have ideas or have had this happen to them? I don't really need to get it to go into first manually but was just curious if it is a sign of things to come. Thanks for any help
Jsdtm is offline
post #2 of 9 Old 10-01-2013, 10:58 AM
LumpyGrits
Worn out shift linkage.
Shift linkage WAY out of adjustment.
BOTH.......
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 9 Old 10-01-2013, 04:10 PM
JeePete
1983 CJ7
Double clutch on the down shift....you'll get 10 more years out of it...
JeePete is offline
post #4 of 9 Old 10-01-2013, 04:38 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Ummm...the OP has an automatic.
Matt
Matt1981CJ7 is offline
post #5 of 9 Old 10-01-2013, 06:47 PM
LumpyGrits
OMG-Are you for real The OP is use'n an AUTOMATIC Trans.....
LG
post #6 of 9 Old 10-01-2013, 08:12 PM
Matt1981CJ7
1981 CJ7
LG
I think there's an echo in here.
Matt
post #7 of 9 Old 10-01-2013, 08:14 PM Thread Starter
Jsdtm
BOTH.......
LG
Thank you. I will check the linkage out this weekend or Friday if I can play hooky. Haha. Is this something that will wear out my tranny of left as is?
Jsdtm is offline
post #8 of 9 Old 10-02-2013, 03:59 AM
JeePete
1983 CJ7
Matt
Ah geez, ADD/OCD kicked in....carry on!! B-)
JeePete is offline
post #9 of 9 Old 10-02-2013, 12:39 PM
LumpyGrits
It ain't going to get any better, only worst.
LG
