This can't be normal, right? - JeepForum.com
post #1 of 13 Old 03-19-2012, 11:42 AM Thread Starter
pagnani
1983 CJ7
Hello all,
I am new to JF and very new to owning a Jeep. I purchased an 83 CJ7 in December. I do not know a ton about cars but am willing to get in and figure things out if I have a little bit of direction. I know you guys will ask me to fill out the info about my CJ but I am unsure how to tell what I have. PO basically took my $1000 and handed me the keys and tittle.
The issue I have is that it is a little rough to start in the mornings. My initial thought is that it's not a huge deal since it's 30 years old, but my issue is the black specks all over the floor near the exhaust. I let her warm up for about 10 minutes in the morning and when I am ready to drive off there is quite the spray of black specs coming out of the exhaust. This pic will hopefully show what I am talking about
pagnani is offline
post #2 of 13 Old 03-19-2012, 11:44 AM Thread Starter
pagnani
1983 CJ7
pagnani is offline
post #3 of 13 Old 03-19-2012, 11:48 AM
Palmetto
Palmetto's Avatar
1981 CJ7
My guess (and I am not a guru, just an amateur) is that the specs are oil.
Seems like it may be worn rings (piston rings) allowing oil to blow by and exit through the valves
and then the exhaust.
I'm sure more seasoned individuals will give you additional info.
ΜΟΛΩΝ ΛΑΒΕ!
Do your duty in all things. You cannot do more, you should never wish to do less.
Robert E. Lee
Groups
Originally Posted by DiabloYJ View Post
It's a Jeep thing, I don't even understand it sometimes.
1981 CJ-7, AMC 360 bored .30 over, Edelbrock Intake, Edelbrock Cam, Edelbrock Double Roller Timing Chain, Holly 650 truck avenger carb, Flowcooler water pump. '97 Dodge 4wd Std NV4500. D300 Twin Sticked. Corbeau Seats, Custom Dash with Autometer guages, Electronic Speedo, all stainless hardware, Outlaw II Wheels, BFG AT 33" Tires, Flex-A-Lite Dual Electric Fan, AGR steering box, Borgeson steering shaft, ididit tilt column, Mean Green Starter, Tuffy console, poly gas tank, handmade rear bumper, cheap radio and speakers.
2000 XJ - HO 4.0L, 245/75R16 Goodyear Wrangler Duratracs. PSC gearbox. IRO Double Shear Trackbar. New headliner. IRO Hack & Tap SYE. IRO adjustable UCA & LCA, RE 3.5" lift, Bilstein 5100 shocks, JKS Quick Disconnects. Future mod: OTK steering, lockers, FIPK, rock sliders, JCR Bumpers, rear storage, high pinion rear (3.55), frame reinforcement, hood louvers, rack lighting.
Palmetto is offline
post #4 of 13 Old 03-19-2012, 11:54 AM
Dngrs1
1979 CJ7
An entirely new exhaust system will take care of that, until the carbon builds up in the new pipes. Seriously, as you live in Utah, where it is probably freezing at night and warmer in the day, condensation will form in the pipes and soften the built up carbon in the pipes and then be blown out when the engine is started. The hard starting could be a number of things. I would start with ensuring the choke is working properly.
Oh, Welcome to the Forum!
Dngrs1 is offline
post #5 of 13 Old 03-19-2012, 11:59 AM
WindKnot
1977 CJ7
Does it eventually dry? If it does, my guess is that the Jeep is running rich and the black fuel smoke is mixing with the condensation.
Normal? As in do a lot of Jeeps do this? Yes. Should they? No, not really. There could be all kinds of reasons why the Jeep is running rich, from just a badly tuned carb to compensating for a lousy choke to something more serious.
Welcome to the monkeyhouse, by the way. Post up in your profile what you do know. As you read more you will learn how to figure out some of the blanks and can update as you go.
In the meantime, check your oil consumption and you might want to do a compression check. The numbers should be within about 10% of each other down the cylinders.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #6 of 13 Old 03-19-2012, 12:02 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Can you provide specific details about the hard starting and what specifically you're having to do to get it running?
..when I am ready to drive off there is quite the spray of black specs coming out of the exhaust.
Postion a paper towel over the exhaust pipe to catch the black specs. Once the towel is really dirty, put it in a bucket of clean water and squeeze it out and see if any oil floats to the surface after the water settles.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #7 of 13 Old 03-19-2012, 12:05 PM
iDriveYJ
x2
iDriveYJ is offline
post #8 of 13 Old 03-19-2012, 12:08 PM
DaddysCJ
Mine does the same thing. If you'll look in the "new guy" post I just submitted, you can see the black infront of LR tire. Thats were my pipes dump. Mine has gutted glasspacks on it I think that will be replaced soon. (way too loud for my wife) I hope its the exhaust system like 1979CJ said.
DaddysCJ is offline
post #9 of 13 Old 03-19-2012, 12:08 PM Thread Starter
pagnani
1983 CJ7
Hard to start
Basically with any older car, I assume there is a ritual. Turn key to on, pump gas a time or two, try to start, after 5 seconds let off, wait a second or two, pump again then try to start. This goes on for about 30 seconds, depending on how cold it is.
I did change the oil, cleaned the air filter, as far as carbs go, I have no idea how to adjust them. I will upload a picture after lunch so you can see what I have. I know it's aftermarket.
pagnani is offline
post #10 of 13 Old 03-19-2012, 05:18 PM
248107
1983 CJ7
Welcome aboard.
Provo Utah ,IRS capital of the world.
Like said fill out the profile and tell what kind of carb you have or description. 6 or 8. and the members will get you going and steer you in the right direction
248107 is offline
post #11 of 13 Old 03-19-2012, 05:31 PM
CJ7Sasquatch
1979 CJ7
Mine does the same thing, just condensation sling with maybe a tad bit rich on the choke, no big worries in my op
ECV 1864
CJ7Sasquatch is offline
post #12 of 13 Old 03-19-2012, 05:50 PM
wellmax
install a new set of autolite plugs
hard start issue: Fuel Filter
fuel filter must be positioned with one pipe in and two out (the outside out pipe must be positioned on top as it goes to the vac canister, the center out pipe goes to the carb.
if the fuel filter is not positioned in this manner, when you stop the engine the fuel can be syphoned out of the carb and back into the fuel tank,
this will cause you a slow hard start next time, as your fuel pump must replace all the fuel that flowed back to carb before jeep will start..
check position of fuel filter and let us know what you find!!!!!!!
at night in a very dark place open the hood with motor running and look at your sparkplug wires, do you see any fire, if so you need new wires.
all these little things add up to slow starts, poor mpg and performance.
what type air filter and what is its condition?
if you have any doubt about the air filter, get a new one, pvc valve and fuel filter.
battery must also be in top conditon to spin the old jeep,
send us a few pictures of your new toy!!
wellmax is offline
post #13 of 13 Old 03-19-2012, 05:54 PM
Trapshooter
First.....Welcome to the Jeep Forum and the CJ family, tons of good stuff here for your new rig.
A couple of pics of your engine, one from either side, would be helpful. Your cold starting issue could be something as simple as a fuel filter not clock properly and draining the carb bowl of fuel.
Good Luck.........
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
exhaust
Is this normal? Agent620 Jeep CJ Forum 8 02-06-2012 05:52 PM
normal oil psi? wetdog Jeep CJ Forum 13 03-25-2009 01:24 PM
Is this normal? mideerhunter Jeep CJ Forum 9 12-27-2005 08:58 AM
Is this normal CGrugger Jeep CJ Forum 22 06-01-2005 09:02 PM
Is this normal? 73CJAZ Jeep CJ Forum 6 02-29-2004 10:09 PM
