Can't find an oil pan for Buick 231? - JeepForum.com
post #1 of 13 Old 12-30-2013, 02:22 PM Thread Starter
Zech
1974 CJ5
I have a Buick 231 in my 1974 CJ5. The motor had low oil pressure when I bought it so I pulled the pan to check the oil pickup. I noticed the pan had welds around it and the pickup had a circular weld around it too. Thought that was weird. The pickup was clogged after sitting for 15yrs. I pulled it and got a replacement and noticed the angle was different. Well the pan has the sump moved to the other side and I think they cut the old pickup and angled it to match the sump. I can't get the pan back on with the new pickup sitting in the shallow side of the pan. I cannot find a pan for this engine anywhere. Its a basic 14 bolt pan that seems common for the era but no one carries one. Got the only one I could find on ebay and he mislabeled it and it was for a v8 and had to be returned. I am stuck and my project is kind of at a stand still. With the numbers on the block I figured it came from a 1979 Buick Skylark. Any help or suggestions would be appreciated.
Zech
Zech is offline
post #2 of 13 Old 12-30-2013, 02:35 PM Thread Starter
Zech
1974 CJ5
Would there be any problems with just taking a hammer and beating the pan out a little so the pick up fits? It is just a tad to short.
Zech is offline
post #3 of 13 Old 12-30-2013, 02:45 PM
Ed Rico
1997 XJ Cherokee
TA Performance Products still lists a chrome stock configuration 14-bolt Buick V6 oil pan on their website at http://www.taperformance.com/proddet...prod=TA_V1511A I was into Buick V6s quite heavily about 20 years ago and Kenne-Bell was the big supplier at that time. Unfortunately, the KB website doesn't seem to list any Buick V6 stuff currently.
Hope this Helps,
-Ed Rico
'97 XJ Sport - New life after engine swap, '93 4.0L w/'97 OBD-II/AW4/NP231/D35(ABS)
Ed Rico is offline
post #4 of 13 Old 12-30-2013, 04:18 PM
Nereussailor
How about this one at Summit http://www.summitracing.com/parts/rn.../submodel/base
I'm not sure what tomorrow will bring, but it can't be any worse than what I've already been through.
Nereussailor is offline
post #5 of 13 Old 12-30-2013, 04:52 PM
Ed Rico
1997 XJ Cherokee
That Summit oil pan is for a SBC and won't fit a Buick V6. The Dorman oil pans listed on Summit's website for V6 applications are all for transverse FWD cars and won't work for a longitudinally mounted engine.
-Ed Rico
Ed Rico is offline
post #6 of 13 Old 12-30-2013, 05:31 PM Thread Starter
Zech
1974 CJ5
Holy crap! That's it! Thanks Ed Rico. Ive been bangin my head against the wall over this for 2months now with the motor sitting opened up in the garage. Thank you so much. I should have started here from the beginning.
Zech
Zech is offline
post #7 of 13 Old 12-30-2013, 05:38 PM
Ed Rico
1997 XJ Cherokee
No problem. You really do want the correct matching oil pump pickup and pan/sump configuration to avoid any problems with the pickup becoming uncovered during cornering/braking. I don't know if the chrome oil pan will make your Jeep any faster, but it can't hurt.
-Ed Rico
Ed Rico is offline
post #8 of 13 Old 12-30-2013, 07:18 PM
Nereussailor
Sorry about my post I should have read a little closer. Is this the same one not chromed? http://www.jcwhitney.com/1977-1979-b...77-1979j1.jcwx
post #9 of 13 Old 12-30-2013, 07:33 PM
Ed Rico
1997 XJ Cherokee
No, that also looks like a SBC oil pan. It definitely won't work on a Buick V6.
-Ed Rico
Ed Rico is offline
post #10 of 13 Old 12-30-2013, 08:06 PM
Nereussailor
It's funny, if you look at the first pictures it looks similar, then you look at the 2 pics below and it's a completely different pan.
post #11 of 13 Old 02-12-2015, 07:20 PM
Huffycj5
I have a 1967 cj5 that has a Buick 231 v6 that needs a new oil pan 20 bolt! Looked everywhere online does anyone know where to find one? Based on engine numbers its from a 1987 Buick!!
Huffycj5 is offline
post #12 of 13 Old 02-12-2015, 09:34 PM
Ed Rico
1997 XJ Cherokee
TA Performance as well as Weber Power Products http://www.weberpowerproducts.com/3-...jc-dsop-20.htm have a deep 20-bolt Buick V6 pan. Kinda pricey, but they don't seem to list a stock 20-bolt Buick V6 pan.
-Ed Rico
Ed Rico is offline
post #13 of 13 Old 02-14-2015, 02:18 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Check for pans for the 80's GM G-bodies: the Cutlass Supreme and Regal had the Buick 3.8. The Monte Carlo I knew of had a Chevy based 3.8l, so watch out for those.
And there were 2 different pan configurations for the Buick 231, one has more of a point to the front of the pan...
Rick
Cutlass327 is offline
