Can't figure out poor turning radius issue - JeepForum.com
post #1 of 28 Old 10-11-2013, 09:02 AM Thread Starter
Grims
1983 CJ7
I have a tie rod flip, and a pitman arm that measure 6.5" center bolt to bolt. The Jeep has about a 6" lift, and 35" tires.
My turning radius is so bad I cannot do a U turn from a turning lane to a double lane without hitting the curb. As far as I can tell my pitman arm should be the correct length, and I am coming no where close to hitting my steering stops, or rubbing on anything. With wheels straight it takes me about 2.5 turns either direction to lock.
The only thing out of the ordinary I see is my draglink is bolted in on top of my pitman arm instead of under...but I wouldn't think that would effect turning radius as it would just adjust the draglink out.
here are some pictures of the steering setup.
http://imgur.com/a/kRTJy
Grims is offline
post #2 of 28 Old 10-11-2013, 09:49 AM
WindKnot
1977 CJ7
You may want to turn the steering all the way to one side and see if the tie rod or steering damper is up against the differential. That tie rod is much thicker than stock, and if it comes into contact with the differential too soon, there goes the turning radius.
There also seems to be some scratched paint on the connecting rod. Is that hitting something?
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is online now
post #3 of 28 Old 10-11-2013, 09:56 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The steering damper looks WAY too long to me, and may be limiting the travel.
Here's my stock steering components with the correct length damper. Notice how much shorter my damper is?
Matt
Matt1981CJ7 is offline
post #4 of 28 Old 10-11-2013, 09:58 AM Thread Starter
Grims
1983 CJ7
Great suggestions guys. I will look at those things. One other thing that seems odd. I have a dropped pitman arm...but it seems my draglink is just as high as your stock one, and mine is flipped.
Grims is offline
post #5 of 28 Old 10-11-2013, 10:07 AM
Matt1981CJ7
1981 CJ7
Grims,
I only have 2.5" of lift. I think yours is more than that. That's why our draglinks have similar angles.
The thing that still puzzles me is why yours takes 5 full turns lock-to-lock. I think mine takes about 3.5 turns, and I can whip a U on a 2-lane road.
Wrong steering box, perhaps? Dunno.
Matt
post #6 of 28 Old 10-11-2013, 10:10 AM
Deeznutz73
1973 CJ5
Can you turn one way more than the other? When I did my power steering swap, I read about people having issues with drop pitman arms and prop per clocking. Before I got the factory one, I used the one off the donor car. I had the same issue with left hand turns but it worked. Now I have bump steer like a mofo. I read that a late 90's Cherokee can be re keyed by using an angled file, allowing you to clock it perfectly for you. This may not be it, but just an idea for a $15 fix (if it's it).
This shouldn't be too hard...........
Deeznutz73 is offline
post #7 of 28 Old 10-11-2013, 10:13 AM Thread Starter
Grims
1983 CJ7
Thanks Deez, but no I can turn the same amount each direction. I also pray to God it's not the steering box...as I just had to use a BFH to get a new steering shaft on it, and I am fairly certain it is never coming off again in one piece.
Grims is offline
post #8 of 28 Old 10-11-2013, 10:16 AM
Deeznutz73
1973 CJ5
Just read Matt's post and I agree. I think mine is 4.25. 3.5 lock to lock is a variable ratio (desirable) for the Saginaw boxes. You may want to check that out too.
post #9 of 28 Old 10-11-2013, 10:36 AM
Matt1981CJ7
1981 CJ7
I was mistaken earlier. I just went out and checked mine, and I too have about 4.25 turns lock to lock.
Matt
post #10 of 28 Old 10-11-2013, 12:26 PM
Deeznutz73
1973 CJ5
Even if yours takes all day to get there, you still should be able to turn tighter than that. When your steering wheel/box is maxed out, left or right, can your tires go any further, if they were disconnected from the box?
post #11 of 28 Old 10-11-2013, 12:32 PM Thread Starter
Grims
1983 CJ7
I don't know, I haven't tried pulling the draglink off the pitman arm yet, but that may be what I need to do next.
I took some more pictures at full lock each direction. it doesn't look like the steering dampner is getting maxed out.
http://imgur.com/a/kmCM1
Grims is offline
post #12 of 28 Old 10-11-2013, 12:35 PM
Dngrs1
1979 CJ7
I remember reading somewhere that the turning circle for an '84 CJ 7 was about 36'. So, depending on the width of the lanes, you may not be able to u-turn from the center turn lane.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #13 of 28 Old 10-11-2013, 12:51 PM
outdoorguy86
1983 CJ7
Loosen uo the botlts on the steering damper. Thats prob the easiest thing to check. That was my issue. Im just running sans steering damper at the moment
Colorado Jeep Club Member #2086
/l , [____],
l---L---OlllllllO-
()_) ()_)=@=)_)
outdoorguy86 is offline
post #14 of 28 Old 10-11-2013, 12:53 PM Thread Starter
Grims
1983 CJ7
Yep, I'll give that a shot when I get home form work this evening.
Grims is offline
post #15 of 28 Old 10-11-2013, 02:21 PM
skizriz
1978 CJ7
The damper isn't the problem,i t's nowhere near at the end of it's stroke. You can see the oil line on the shaft where it stops.
skizriz is offline
