Can somebody check my Vac. Diagram and answer some questions? - Page 2 - JeepForum.com
post #16 of 21 Old 08-13-2009, 12:41 PM Thread Starter
attworth
1979 CJ7
Originally Posted by Mike Romain View Post
Well if you ever get up to the east coast of Canada, I'll take you up on those.
My wife's been wanting to visit PEI, so maybe...
Are you in Quebec or Newfie?
attworth is offline
post #17 of 21 Old 08-13-2009, 01:44 PM
Mike Romain
The other one, Nova Scotia, near Halifax. We are on a river about 7 km up from the ocean in Chester basin. My wife and I just went out this afternoon and caught two nice brook trout and 4 white perch that were big enough to keep, tossed back a bunch. Let us know if you head up this way and we can show you around. PEI isn't even that far, it is a small area.
Mike
Mike Romain is offline
post #18 of 21 Old 08-13-2009, 01:48 PM Thread Starter
attworth
1979 CJ7
Ah yes, forgot one. Sorry about that!
We'd love to make a trip up there. I miss the snow. (I'm a native cheese-head -Wisconsonite.)
Maybe next Fall/Winter.
attworth is offline
post #19 of 21 Old 08-14-2009, 02:57 PM Thread Starter
attworth
1979 CJ7
Think I just have one more question.
This first picture is on the carb. I believe that is the choke? There's a threaded fitting. It used to be tied into the exhaust manifold via a metal pipe (second picture.) Any ideas what to do with this stuff?
Thanks again.
Edit: the new exhaust manifold does not have the threaded fitting.
attworth is offline
post #20 of 21 Old 08-15-2009, 05:03 AM
Mike Romain
Thanks again.
Then you can just get an automatic timer choke for an 86 maybe. That would involve a bit of wiring. Does your engine have the oil pressure electric switch on the oil pressire sender? If not, you can get one and feed it fused 12 volts from the fender solenoid, then from the oil pressure switch the wire goes to the 86's electric choke to open it. It opens by how long it sees 12 volts.
I prefer a manual choke though. That way I can drive it when it is warming up without needing 3 feet. The manual choke kits go in easy and have all the parts needed.
Mike
post #21 of 21 Old 08-15-2009, 07:46 AM Thread Starter
attworth
1979 CJ7
I was hoping you would say plug the hole.
What type of manual choke kit do I need? Is this something that the local parts store would have and I just "make it work?"
Thanks again Mr. Romain.
attworth is offline
Model 20 questions - need a yes or no answer? 0lll077cj5 Jeep CJ Forum 2 04-06-2009 01:39 PM
no one can answer oil leak jallen760 Jeep CJ Forum 6 12-06-2008 05:49 PM
what is a jumper wire to use to check the check engine light codes. vilentj Jeep CJ Forum 3 07-09-2008 08:29 PM
Need An Answer, Please bigpapahutch Jeep CJ Forum 7 09-23-2007 12:51 PM
answer this wheelchairman Jeep CJ Forum 3 08-10-2006 11:43 PM
