Can a One Piece Axle warp? - JeepForum.com
post #1 of 16 Old 01-17-2010, 10:13 AM Thread Starter
CJman77
1977 CJ7
Is this even possible?
I am having a one piece wobble and I think its poor spacer grinding to blame. I dont believe a hardened steel axle can warp or be bent. Can it?
Brian
CJman77 is offline
post #2 of 16 Old 01-17-2010, 10:59 AM
Mike Romain
I have seen (and done) way more than one axle bent so they sure can. Usually from a sideways slide into a curb in the snow, but it can happen off road too.
Mike
Mike Romain is offline
post #3 of 16 Old 01-17-2010, 12:54 PM
80cj
80cj's Avatar
1980 CJ5
Have a machinist dial indicate it between centers on a lathe.
80cj is offline
post #4 of 16 Old 01-17-2010, 02:57 PM Thread Starter
CJman77
1977 CJ7
Okay well i have some major issues.
When I put the rotor on and turn the axle I have a wobble. So where do I start? I guess I need to have the axle tested like 80cj says?
Any other suggestions?
CJman77 is offline
post #5 of 16 Old 01-17-2010, 03:43 PM
80cj
80cj's Avatar
1980 CJ5
When you turn the axle without the rotor on, does the axle flange seem to run true?
80cj is offline
post #6 of 16 Old 01-17-2010, 04:04 PM Thread Starter
CJman77
1977 CJ7
Not sure. It really does seem to run true.
But the rotor makes it look wobbly. Could I really just have a rotor warped that badly?
I just checked to a straight edge and it seems straight. But I dont know, once I put brakes and everything on I have rubbing issues with the brakes.
CJman77 is offline
post #7 of 16 Old 01-17-2010, 05:14 PM
thantos858
1974 CJ5
Get a dial indicator and check both. Its really easy to warp a rotor if you have brake problems.
thantos858 is offline
post #8 of 16 Old 01-17-2010, 05:19 PM Thread Starter
CJman77
1977 CJ7
Rotors are brand new.
CJman77 is offline
post #9 of 16 Old 01-17-2010, 05:50 PM
80cj
80cj's Avatar
1980 CJ5
I don't know if you could apply this spec to the rear discs but the Jeep specs for rotor runout on the front discs is .005".
80cj is offline
post #10 of 16 Old 01-17-2010, 05:50 PM
wrongway92407
wrongway92407's Avatar
Doesn't matter it all comes from China! You can buy a cheap dial indicator and a magnetic mount from Harbor Freight around $20. I know that you have been having trouble with the pads rubbing but you never said if it is in a certain spot if they rub all the way around. One way to tell if it's the rotor, switch with the other side
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
post #11 of 16 Old 01-17-2010, 06:08 PM Thread Starter
CJman77
1977 CJ7
Yeah It def a certain section that they rub
CJman77 is offline
post #12 of 16 Old 01-17-2010, 11:06 PM
wrongway92407
That tells you that something isn't straight. I would change sides if it's not to much trouble. I want you get all the bugs worked out, as soon as the weather gets better I will be doing mine. Make sure that there is nothing on the axle mounting surface and on the inside of the rotor. If the parts house where you bought them turns drums (Kragen, Oreillys) they can put it on the machine and tell you how much it's out.
Wrongway
My fleet:
post #13 of 16 Old 01-18-2010, 07:20 AM
deadeye
1983 CJ7
I lot of the new rotors are made to be turned before you use them.
They are all made in china now and are junk.
83 CJ7, 350 TBI, TH350, Dana 300 twin stick, Dana 44 E-locker, Ford 8.8, Detroit, 4:10 gears, 35x13.5x15s
"Just Exchange Every Part"
deadeye is offline
post #14 of 16 Old 01-18-2010, 03:46 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
who did you get your one pieces from? i would definately start by checking the hub run out. are you doing the disk upgrade at the same time you are doing the 1 piece?
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #15 of 16 Old 01-18-2010, 05:08 PM Thread Starter
CJman77
1977 CJ7
Yes doing the disk also. I am doing a frame off. Had the diff rebuilt with a new ring and pinion by a local shop.
Okay So I got a magnetic base and dial indicator. Both axles are less then
.007 off. They are identical. However the rotors are approx .02 or a bit more off at certain points. (Kinda off both directions)
So I think I will have the rotors machined a little and then if it drags at all after I will sand the pads a bit. I think everything is okay. Mainly Cheap Rotors to fault.
CJman77 is offline
one piece axle kit? rocesride Jeep CJ Forum 19 12-13-2009 04:40 AM
2 piece to 1 piece AMC20 axle swap question Robb Kiker Jeep CJ Forum 11 11-17-2009 08:01 PM
amc20 one piece axle turns axle to open diff? 84cj7jd Jeep CJ Forum 6 04-08-2009 09:23 AM
One piece axle kit Gotta83CJ Jeep CJ Forum 6 05-31-2008 02:34 PM
One Piece Axle diamatron Jeep CJ Forum 14 01-09-2002 04:50 PM
