Can my T-150 handle a strong 360? - Page 2 - JeepForum.com
post #16 of 24 Old 09-02-2012, 02:51 PM Thread Starter
johnnyray401
Originally Posted by hutch1200 View Post
Again, it depends if you're doing technical rocks, Malling or spinning through mud.
Probably going to be doing a bit of each!
Anyways, thanks for all the information, opinions, and BS For time and money's sake, we'll keep the t-150 in there until we break it or get tired of it
johnnyray401 is offline
post #17 of 24 Old 09-02-2012, 03:46 PM
80cj
80cj's Avatar
1980 CJ5
If you plan on doing rocks then think about your D30 front axle. You don't give any info on tires and the rest of your drive train in your profile.
80cj is offline
post #18 of 24 Old 09-03-2012, 12:21 PM
JakeRod13
1978 CJ7
I have a T150 behind my mild sbc350. It gets the job done for me.
JakeRod13 is offline
post #19 of 24 Old 09-05-2012, 05:29 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The T150 is in reality a Ford 3.03 RAT three speed. This trans was found in both cars to pickup trucks. It is a very strong transmission and will hold up well to most abuse. Of course you can break anything if you pound on it hard enough.
As for a slick shifting four speed. The T176 (another Ford offering, I believe it was designated the RUG) is as good as you're going to get with a bolt in four speed trans that shifts smoothly and will hold up to regular abuse. Otherwise, you can look at an early car four speed. T10's were popular back in the day, and adapters were available (from AA) but the trans may be cost prohibitive now.
jeepdaddy2000 is offline
post #20 of 24 Old 02-22-2013, 10:45 PM
CJ5Valvefloater
1976 CJ5
I ran this Engine Tranny combo for a long time with no problems per say took out a cluster gear in 1983 and rebuilt the transmission and never had another problem with it. I did not run it soft either. I converted over to a Ford top loader 4 speed about 5 years ago but the T-150 was still going strong at that point. I still keep the T-150 around for a back up in case I break the top loader.
CJ5Valvefloater is offline
post #21 of 24 Old 02-22-2013, 11:36 PM
carnuck
1984 J-Series Truck
Be careful with 2nd gear. That's the weak point in those 3 speeds.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #22 of 24 Old 02-23-2013, 01:07 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
JeepDaddy2000...I was TOTALLY unaware that a T-10 could be fitted. Darn it all to heck!
Edit: I loves the T-10. And I have 1 that had a fresh "bench build" done to it. I didn't do my reseach/due diligence. 10 seconds found me this.
http://www.northwestfab.com/Borg-War...ter_p_283.html
But after making my own skidplate, mounts, extending the t-case rods and the Novak adapter for the T-18...it seems a tad late.
My buddy, who copied my CJ down to the color, wiped his barely used T-176 behind his semi-warmed crate 360. He's a fairly moderate mall crawler w/33s. Kinda made me gun-shy of the T-176 for use in my 400+ hp all glass CJ.
For my personal knowlege, are my fears of the T-176 for a performance engine unfounded? It "seems" to be the trans I should be using. I just trail ride, loves me mud and like the light to light street drags. Not much into "technical rock crawling"
Maybe I'll have to build another copy of this CJ for comparison. Research. For the benefit of mankind. Maybe throw a solar panel on the hood and see if I can score a Fed Grant!
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #23 of 24 Old 02-23-2013, 05:05 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hutch,
Don't forget about the T-19. You can get it with 4:1, 5:1, or 6:1 first gear, and it's synchronized, so you don't have to be at a full stop to get it into 1st, like you do with a NP435 and T-18.
With a factory Jeep T-18 shifter, the T-19 throw is quite short. I can run thru all my gears without lifting my elbow off the center console. If you are seriously shopping for something different, I can snap some shots of the shifter position in all gears. It really is comfortable to drive.
Anyway, I thought I'd throw that out there. For some reason, the T-19 gets overlooked in these threads, perhaps because it's not as common.
Matt
Matt1981CJ7 is offline
post #24 of 24 Old 02-23-2013, 04:07 PM
hutch1200
hutch1200's Avatar
1979 CJ7
Matt, untill you mentioned it, I'd never heard of the T-19. Which of course would also suit my needs better. Meh, at least I have a bullet-proof trans. SLOW, but solid. I can take solace that I got a barely used Novak trans w/adapter...for $100 over the price of just the adapter. Maybe I shouldn't be speed shifting a hi-po, 4,000 lbs vehicle w/35" tires.
Of course, maybe it's Gods' way of telling me that my rollbar has seen enough use!
Thanx for the pix offer Matt, but the T-18 is in until it breaks. Now, since I've said it aloud, everything else AROUND it will break..except the trans itself!
strong strong gasoline odor stephenxchen Jeep CJ Forum 17 06-29-2012 01:04 PM
8 lug 44 front, strong enough? GVHS Jeep CJ Forum 7 01-08-2012 01:36 PM
Not as strong as I used to be... redfin188t Jeep CJ Forum 18 10-24-2011 06:38 PM
how strong is a dana 44? BIGKURT666 Jeep CJ Forum 16 02-07-2009 12:45 PM
T-4 strong enough? JRS Jeep CJ Forum 6 08-06-2001 11:25 AM
