Can I use narrow track carrier bearing caps on a wide track axle - JeepForum.com
post #1 of 11 Old 01-26-2011, 08:54 AM Thread Starter
aero mech
aero mech's Avatar
1980 CJ7
I purchased a wide track dana 30 housing this weekend and was wondering if I can use my narrow track carrier bearing caps to build it? The PO of the wide track housing didn't have the caps just the housing. Thanks JC
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline
post #2 of 11 Old 01-26-2011, 09:01 AM
JeepnBlake
In short yes.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #3 of 11 Old 01-26-2011, 09:13 AM
CSP
You shouldn't. Carrier bearing caps are line bored with the center section. Using caps from another axle housing can distort the carrier bearings as the holes may not be perfectly round.
CSP is offline
post #4 of 11 Old 01-26-2011, 09:24 AM Thread Starter
aero mech
aero mech's Avatar
1980 CJ7
OK one yes and one no. I just talked to the PO again and he now says he thinks he found them. I know there are arrows to loacte up and down in the carrie but how do you know right from left if no one marked them. thanks jc
post #5 of 11 Old 01-26-2011, 09:40 AM
fredrok
This is 100% correct.
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
post #6 of 11 Old 01-26-2011, 09:52 AM
CSP
There should be letters stamped, not arrows. One side will have an A that's rightside up (just an example) and the other side will have it upside down. Match the orientation of the arrows to the stamp on the case along with the location to get them on correctly.
CSP is offline
post #7 of 11 Old 01-26-2011, 10:53 AM
foggybottombob
Actually one side will have a letter that is vertical and the other side will have that same letter horizontal. Match the letter orientations on the bearing caps with the orientation of the letters on the face of the diff housing. Once you see the letters it becomes obvious. I've not seen a diff that did not have the vertical/horizontal letter marks but I assume there are exceptions.
foggybottombob is offline
post #8 of 11 Old 01-26-2011, 11:19 AM
jqramm35
1982 CJ7
NO Axle without the caps is scrap.
jqramm35 is offline
post #9 of 11 Old 01-26-2011, 11:30 AM Thread Starter
aero mech
aero mech's Avatar
1980 CJ7
Thanks guys, Just talked with the PO again he says he found the box with the all the internals. He is sending me the caps . thanks for all the input.
post #10 of 11 Old 01-26-2011, 01:03 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
A "quick and dirty" way to check the caps is to install them and then see if you can "feel" a lip at the mating surfaces. If they're the correct caps in the correct orientation, the parting line should be smooth to the touch..
BESRK is offline
post #11 of 11 Old 01-26-2011, 01:22 PM Thread Starter
aero mech
aero mech's Avatar
1980 CJ7
THANKS BESRK FOR THE TIP, ALSO THNAKS FOR THE AMC 20 TRUSS a+ WORK jc
Axle Swap from narrow track to wide track 1979CJ7newguy Jeep CJ Forum 19 05-02-2013 02:26 PM
Narrow track to wide track swap, mods? greene76 Jeep CJ Forum 8 12-23-2009 09:00 AM
Carrier from Narrow Track into Wide track sanmiam Jeep CJ Forum 2 07-26-2007 08:21 AM
Front axle wide track/narrow track?? Joey_B Jeep CJ Forum 17 10-16-2006 03:44 PM
ring and Pinion swap from Narrow Track to Wide Track From78To83 Jeep CJ Forum 1 04-05-2005 02:15 PM
