Can I use manual steering brackets with power steering box? - JeepForum.com
post #1 of 3 Old 12-27-2005, 06:49 PM Thread Starter
Mud Machine
Jeep Addict
Mud Machine's Avatar
Just bought a power steering box for my 1976 CJ-7. Can I bolt this up to my excising manual steering box frame brackets? Will these be strong enough or do I have to use power steering specific brackets?
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS-III, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #2 of 3 Old 12-27-2005, 07:55 PM
John N
1981 CJ8
The box mount brackets for the frame should work fine, if they aren't cracked (common problem). You will need a p/s pitman arm, they aren't the same.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 3 Old 12-27-2005, 09:26 PM
Rockram1
The bracket is the same. But the pitman arm, and the input shaft are different. You'll need to get the lower part of the donors steering shaft as well.
86 CJ7, 258, t18, D300, D44's 4.56's, Detroit front, Warn shafts and CTM joints, spool rear, SOA, SRS, waggy springs, 6 point cage, Warn winch, 38" Tsl, Allied beadlocks.
Rockram1 is offline
power steering to manual steering? sbcranger Jeep CJ Forum 10 07-29-2009 06:53 AM
Power Steering Brackets FoMoCoSVT Jeep CJ Forum 2 06-28-2008 05:00 AM
power steering vs. manual steering certifiablejeep Jeep CJ Forum 7 05-25-2004 11:15 AM
Manual Steering to Power Steering 79 CJ7 Spurgeon Jeep CJ Forum 3 09-25-2003 07:25 PM
power steering pump brackets KG4PAM Jeep CJ Forum 1 01-16-2003 03:49 PM
