Can I cut this off? - JeepForum.com
post #1 of 6 Old 02-16-2008, 08:17 PM Thread Starter
fluid_grind
fluid_grind's Avatar
1978 CJ5
Can I cut this off?
Mocking up my exhaust and could use the extra clearance at my transfer case. What if any thing is bolted to the two holes in the photos below in the plate on my D20 transfer? I don't remember anything being bolted there, but its been a while since the tear down. If they go unused, can i cut the plate back to make more room for my exhaust?
Black 94 YJ, 4.0 L, 5 speed, RE 2.5 Standard Lift, 2" BL, 32 X 11.5 Mud Rovers on Black 8 X 15 steel Pacers, Warn winch.
78 CJ5, rebuilt 360, with T-18 Transmission, D20 transfer with teralow, Dana 44s with OX lockers front and back, 4.88 gearing, SOA with RE 1.5 lift springs and high steer, 37x13 Boggers on 16" MT Classics : Project Jeep
fluid_grind is offline
post #2 of 6 Old 02-16-2008, 09:18 PM
crusty75
1975 CJ5
Mounting point for the anti-torque mount? (If 78's had such a thing) How does it feel when you romp on it? Any knocking or klunking or weird vibes? If not run it for a while to make sure, then cut it off, if you really feel the need. Good way to ruin a nice case, though.
Me? I'd find a way to not cut the case.
crusty75 is offline
post #3 of 6 Old 02-16-2008, 09:42 PM
Trapshooter
I have to agree with crusty75, its there for a reason. Maybe someone can post some pictures of their unit and shed some light on what the mount might be used for.
Trapshooter is offline
post #4 of 6 Old 02-17-2008, 10:34 AM
Mike Romain
One of those holes had a bolt in it from the looks of it's threads. Maybe an exhaust hanger?
Mike
Mike Romain is offline
post #5 of 6 Old 02-17-2008, 11:30 AM
wh74415
1979 CJ7
its for stock exhaust hanger. no other purpose. cut that junk.
wh74415 is offline
post #6 of 6 Old 02-17-2008, 11:47 AM
Mike Romain
If it's for sure the exhaust hanger spot, I would only cut enough to clear and still use it. One shop forgot to put my tranny exhaust hanger on and the system kept coming loose at the manifold until I spotted the missing hanger.
Mike
