Can i adapt ANY bucket seats - JeepForum.com
post #1 of 27 Old 06-05-2012, 05:41 AM Thread Starter
Wilderness
1978 CJ7
I was thinking of posting an ad on CL for some bucket seats, but will i have a hard time making them work? I guess you would just have to make them mate up with the original cj seat frame?
Wilderness is offline
post #2 of 27 Old 06-05-2012, 06:22 AM
82JeepCJ7
1982 CJ7
I put seats out of a Mazda 626 in my Jeep. I welded a piece of 1/2"x2" flat bar across the bottom of the seat frame at the same distance as the holes for the original CJ seat mount. The holes were drilled and tapped so they would bolt to the original mount with no issues.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is online now
post #3 of 27 Old 06-05-2012, 06:55 AM
CoAce
1977 CJ7
I did the same with XJ seats. Add a flat bar and bolted in.
The only thing to watch for is the thickness of the bottom. If to thick you will sit way to high like I was from the po's install.
CoAce is offline
post #4 of 27 Old 06-05-2012, 07:52 AM
CSP
Yep, seat with a thick lower cushion can be a pain. Saturns have a lower cushion thickness that works well in a CJ.
CSP is offline
post #5 of 27 Old 06-05-2012, 04:34 PM
skizriz
1978 CJ7
I just tossed out two nice power/heated seats because the bottom cushions are too high. Too much trouble to make new brackets for me.
Small GM cars will swap right in. Cavaliers,Sunbirds, etc...
skizriz is online now
post #6 of 27 Old 06-05-2012, 05:04 PM
scottymac62
1979 CJ7
A welder and a plasma cutter = anything fits!
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #7 of 27 Old 06-05-2012, 05:04 PM
tdkask
I have two early TJ seats (they changed half way through TJs, I think?) but decided to make my own brackets. You can put just about any seat in the way mentioned above, but you'll want to make sure it's not too wide or too high. I'd suggest something that somewhat wraps around you and helps old your butt in place, but has some cushion under and behind you. Beyond that, maybe consider weather resistant?
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #8 of 27 Old 06-05-2012, 07:26 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
I can't believe you did that.. heated/power seats, because you couldn't lower your mounts? come on, its not that tough.. remember if its over the counter, most likely its made in China! and you wouldn't want that would you?
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #9 of 27 Old 06-05-2012, 07:27 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
love the looks of those seats, how's the height on them? or did you lower the mounting?
frhrwa is offline
post #10 of 27 Old 06-05-2012, 08:27 PM
LimeLite
1978 CJ5
Any tips or links you could pass along for lowering the mounts? I'm not happy with the height of my aftermarket bestops and would like them lower.
78 cj-5 4" procrap lift on 35's amc304 "custom" rear bumper/tire carrier combo, rollcage...
Ex-Member of offroad nuts
LimeLite is offline
post #11 of 27 Old 06-05-2012, 09:09 PM
82JeepCJ7
1982 CJ7
I changed where the seat pivot is to fold the seat forward. I removed the front pivot, then set a level on the top of the frame and lowered the front down until the frame was level. I then drilled a new hole in the frame where the pivot is at and put a bolt with a nylock nut on it. The seat pivots the same as before, but the base of the seat sits level. I have some pictures around here somewhere from when I did it.
post #12 of 27 Old 06-05-2012, 09:13 PM
jeepwhore
....... I have some pictures around here somewhere from when I did it.
Yes please!
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #13 of 27 Old 06-05-2012, 09:37 PM
82JeepCJ7
1982 CJ7
Ok, I finally found them.
Here is the seat frame as it comes from the factory.
I removed the front pivots, and brought the front link backward so the frame is sitting level. It's clamped into place with some vice grips in this shot. Make sure both sides are moved back the same distance so the fold forward function will still work.
The pivot was replaced with a 1/2" bolt and Nylock nut.
Flat bar welded to the bottom of the seat frame. Holes were drilled to match the factory seat frame so it bolted right up.
The end result. The seat bottom is flat and they sit just right so the back of your legs are not hanging off the edge. The sliders work the same, and these seats have the reclining back and lumbar support.
post #14 of 27 Old 06-05-2012, 09:55 PM
jeepwhore
Sweet! So how are they for overall height?.....Assuming you're not like 6'8" or something.
And is that pivot some kind of funky press in insert? It's not a bolt from what I remember.....
post #15 of 27 Old 06-05-2012, 10:24 PM
John87
i have seats from a 94 s10 blazer in mine
-John
°llllll° 1985 CJ-7
John87 is offline
Quick question re YJ bucket seats Colt44 Jeep CJ Forum 6 01-30-2012 10:34 PM
low or high back bucket seats? benullman Jeep CJ Forum 14 07-08-2011 04:35 AM
Rci body-contoured bucket seats bhurt Jeep CJ Forum 4 08-17-2010 06:17 PM
Bucket seats in the back of a CJ? Kryptae Jeep CJ Forum 2 08-26-2009 08:10 PM
bucket seats on 57 cj5 ktm25089 Jeep CJ Forum 9 04-29-2008 01:13 PM
