Can the clutch from a 258-T18 combo be used on a 258-T5? - JeepForum.com
post #1 of 3 Old 09-24-2011, 06:51 PM Thread Starter
10129
I just bought a new 258 with a new center force clutch on it. It was mated to a T18 tranny. Will it work on mt T5?
10129 is offline
post #2 of 3 Old 09-24-2011, 07:47 PM
lucdog
lucdog's Avatar
1980 CJ5
I believe the T-4 (T-5 is the same ) has a 1.125" input shaft diameter. The Jeep T-18 has a 1.0625 input shaft, both are 10 splines
The Ford T-18 has a 10 splines and 1.125" input shaft. So it depends if its the Ford or Jeep transmission.
The pressure plate is the same, only the pilot and friction disc might have to be changed, IIRC.
Input shaft length needs to be checked also.
I'm not certain with the pilot bearing.
Call Advance Adapters or Novak-adapt, to be sure.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 3 Old 09-26-2011, 06:55 AM
CSP
Some right info there, some wrong.
Ford inputs are 1-1/16" (1.0625), not 1-1/8".
Only the '76-79 CJ T18's have the 1-1/16" input. All others, including 72-75 CJ and all FSJ T18's, are 1-1/8", same as the T4.
CSP is offline
What tires and rim combo?? FireEngineRed Jeep CJ Forum 27 06-24-2010 07:40 AM
Clutch for 360/tT18 combo? fluid_grind Jeep CJ Forum 1 09-15-2007 03:57 PM
What is the best combo? Strike Three Jeep CJ Forum 7 04-17-2007 07:54 AM
Clutch works but I hear a whirring when I press the clutch pedal to the floor? part.changer Jeep CJ Forum 12 04-10-2007 02:31 PM
T5 + Dana 300 combo... BroncoFan Jeep CJ Forum 6 01-12-2006 09:10 PM
