can the backside of a fuse block be worked? - JeepForum.com
post #1 of 5 Old 05-10-2013, 09:44 PM Thread Starter
WindKnot
1977 CJ7
Or am I forced to cut around the block? I'm not getting feed to some fuses. Given my "druthers" I'd rather fix the block. I don't want to be THAT GUY.
Any one do this? 1977
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #2 of 5 Old 05-10-2013, 10:13 PM
EgulAye
1980 CJ5
I've had the fuse block out of my '80 a few times. You can work with it for sure.
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #3 of 5 Old 05-11-2013, 03:47 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I've done it also.
You might have to drill out some rivets and clean the connecting bars. Then bolt/solder/both them back together.
John Strenk is offline
post #4 of 5 Old 05-11-2013, 07:20 AM Thread Starter
WindKnot
1977 CJ7
Thanks.
I'll go stare at it for a while...
WindKnot is offline
post #5 of 5 Old 05-11-2013, 08:00 AM
John Strenk
1976 CJ5
Not much to see. A lot of rust and corrosion.
Here is the best schematic that actually shows the back side of the fusebox
I was trying to find some stuff also...
