Can an Axle be Checked for Straightness? - JeepForum.com
post #1 of 3 Old 05-17-2003, 01:29 AM Thread Starter
DJC
1979 CJ5
Not the Housing but the Axles.
Is there any easy way to check an axle and see if it is Straight or Bent? I have a suspect axle that fell over once on a concrete floor and may be bent. Would like to check it for Straightness.
Dial indicator?
DJC is offline
post #2 of 3 Old 05-17-2003, 08:33 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Here is a quick way to check at home. Drill a small cavity in the table of a drill press. Place a ball bearing in the cavity and place the axle on it. Place another ball on the top of the axle. Run the chuck down on the bearing and turn the drill on. Observe any variance in the shaft. On the side, I doubt that tipping an axle over will do any real damage.
jeepdaddy2000 is offline
post #3 of 3 Old 05-17-2003, 12:04 PM Thread Starter
DJC
1979 CJ5
Thanks much Appreciate the reply.
DJC is offline
amc20 one piece axle turns axle to open diff? 84cj7jd Jeep CJ Forum 6 04-08-2009 10:23 AM
Checked compression on the 4cyl...it's tired so on to plan s"B"c 243 Jeep CJ Forum 1 05-19-2008 10:19 AM
Changing my AMC 20 rear axle....and if I used a Land Rover series III axle? Frankcr Jeep CJ Forum 0 09-15-2007 02:13 PM
Narrowtrack rear axle with 2" spacers match up with a widetrack front axle? Blthomas Jeep CJ Forum 1 05-11-2007 09:25 PM
