camshaft replacement - JeepForum.com
 3Likes
post #1 of 17 Old 08-20-2017, 10:33 AM Thread Starter
pjaskins
1959 CJ5
I have a 79 CJ5 - 304. Can I replace the camshaft without removing the engine?
pjaskins is offline
post #2 of 17 Old 08-20-2017, 11:47 AM
waynaferd
Sure can just have remove everything in front of the engine to pull it out thru, radiator, grill, timing cover, water pump etc.
A 55 '5 and a 77 '7
waynaferd is offline
post #3 of 17 Old 08-20-2017, 01:30 PM
pedal2themetai
1956 CJ5
HI, when replacing the cam you should always replace the lifters too. or you can wipe out a new cam with old lifters because of ware pattern... Most cams are sold as a cam and lifter kit.
You would have to pull the head to replace the lifters but you don't have to pull the motor. just remove everything up front.
good luck
tim
pedal2themetai is online now
post #4 of 17 Old 08-20-2017, 01:46 PM
chris989604
1980 CJ7
There is no need to pull the head to change lifters, Just the intake needs to come off.
The only bad part of changing it in the jeep is the oil pan. Trying to get a timing gear cover to seal to the front of the pan is not the easiest when the pan is installed first.. If you can drop the oil pan, I think it is worth the extra few minutes of work.
chris989604 is offline
post #5 of 17 Old 08-20-2017, 04:33 PM
gmakra1
This is incorrect on a 4.2 engine.
gmakra1 is offline
post #6 of 17 Old 08-20-2017, 04:57 PM
swatson454
1983 CJ7
It's a 304: too much time standing next to your still
Shawn
222Doc likes this.
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #7 of 17 Old 08-20-2017, 09:32 PM Thread Starter
pjaskins
1959 CJ5
Got it, thanks for the input, new lifters came with the cam and an Edlelbrock manifold and carb are being installed also. Oil pan is off, it leaked badly, I think putting it on after the timing cover is installed will be the most effective in stopping leaks. Suggestions? pja
pjaskins is offline
post #8 of 17 Old 08-20-2017, 11:04 PM
chris989604
1980 CJ7
THe pan will go on after the front cover. Make sure everything is squeaky clean. Use a dab of rtv in the corners of the pan.
If you have the time and $, switch from using bolts to studs for the oil pan. most hardware stores like ace have them or order them from summit. for ~20$ it will save a lot of headaches.
post #9 of 17 Old 08-20-2017, 11:59 PM
TIPPEDITOVER
In the Lab
TIPPEDITOVER's Avatar
1978 CJ5
Please please please use a break in oil with tons of ZDDP formulated in it when you break it in, so your cam/lifters can live a long happy life.
Shaun
1978 CJ5 to CJ6 - Build in progress......
TIPPEDITOVER is offline
post #10 of 17 Old 08-21-2017, 04:16 AM
gmakra1
[QUOTE][It's a 304: too much time standing next to your still /QUOTE]
Yupe I maybe next to my still too much you though spend way too much time in your coffin.
Dang Shawnster for once and only once you are correct!
BTW you owe me a call Yankee!
gmakra1 is offline
post #11 of 17 Old 08-21-2017, 11:58 AM
swatson454
1983 CJ7
[quote=gmakra1;38773841]
Sorry I missed you, Georgie but you know how cocaine, Russian gymnasts and strippers can be- livin' the dream! I'll try to give you a call when we chopper from the yacht into my private resort in Aruba.
Stay thirsty, my friends! Lol!
Shawn
post #12 of 17 Old 08-21-2017, 08:52 PM
80cj
80cj's Avatar
1980 CJ5
A number of years ago I changed the timing chain on a 76 CJ-5 with 304 without having to drop the oil pan. As I remember there were some specific instructions in the FSM. One thng I do remember was using a liberal amount of RTV. No problems with leaks.
80cj is offline
post #13 of 17 Old 08-22-2017, 07:35 AM
shadoow
any suggestions on a specific oil brand/weight ??
shadoow is offline
post #14 of 17 Old 08-22-2017, 09:03 AM
STJP
Here is one brand of break-in oil for flat tappet cams.
Crane Cams 10W-40 Part Number 99300-1, Driven Break-In Oil
On the Crane website there is also a good explanation of break-in procedure.
http://www.cranecams.com/uploads/breakin/548e.pdf
Cheers,
JS
shadoow and TIPPEDITOVER like this.
STJP is offline
post #15 of 17 Old 08-22-2017, 06:35 PM
258
Cj
Is there specific kit for the ('85) 258 4.2L as far as studs go for the oil pan? I am dropping my oil pan in the next couple months and would like to look further into this. Which brand is preferred?
258 is offline
