Cam and Valve Timing Questions - JeepForum.com
post #1 of 2 Old 04-19-2002, 01:23 PM Thread Starter
Jami
1973 CJ6
Post Cam and Valve Timing Questions
Ok, here is a quick overview of what I have. I have a Crower cam in a 304, I bought the engine used with the camshaft in it. Now I dropped the engine in and got a new wiring harness but had to get someone to put it in because of time. He said he couldn't get it to turnover because the crank sprocket was advanced. So he put it back to 0 degrees.It runs alright but it does not seem like power is where it should be.
I am wondering if the crank sprocket should actually be advanced the 4 degrees or so, and if it was actually some other reason it would not turnover. I just do not want to pay to get it advanced again and have it not start. Any help in this area would be great. Thanks
73 CJ-6 in the works
Jami is offline
post #2 of 2 Old 04-19-2002, 10:18 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
Crower makes a number of cams with different grinds. You need to find out what cam you have and call the company and find out what their recomendation is. Usually only cams with radical grinds need to be advanced via the timing chain. It is possable that he has made a mistake. You might make sure the ignition timing is right for the cam also.
bazinga
jeepdaddy2000 is offline
2 timing questions for 258 imtheant Jeep CJ Forum 21 09-07-2009 11:34 AM
Valve Timing AMC 360 sevenlitre2002 Jeep CJ Forum 6 02-19-2009 06:07 PM
Timing Questions for my 304 V8 soccerpapa Jeep CJ Forum 8 07-28-2007 09:07 AM
timing and vaccum questions..... RockScar Jeep CJ Forum 2 06-20-2007 04:00 PM
timing and other misc questions awalp Jeep CJ Forum 3 04-18-2007 12:31 PM
