Cam questions - JeepForum.com
post #1 of 7 Old 03-25-2014, 01:21 PM Thread Starter
ckyaj
1980 CJ7
Cam questions
Hey guys new to this. Im building a GM 350 fuel injected to go into my cj7. First time doing this so im kind of making it up as i go along. Im trying to figure out what kind of cam to put in there. Im mainly going to use it for trails and mild crawling. Im not building a crazy high horse motor. I just want something that is going to sound good and have a mild lope. Any suggestions.
ckyaj is offline
post #2 of 7 Old 03-25-2014, 01:48 PM
crouse11c
First what gears do you have and heads. This will make the differance. There is a program on compcams website that will help you decide. Just make sure to answer questions correctly. Thy have a program called cam quest also that does it with out waiting for response. But I would answer the questions an they will fit what you want.
crouse11c is offline
post #3 of 7 Old 03-25-2014, 02:03 PM
dg6772
I contacted comp cams as I am doing the same. My 7 has 4.10 gears and a 700R4. They suggested. # 12-249-4 for me. Good from idle to 5500 if I remember correctly.
Dave in Muskegon using JeepForum
dg6772 is offline
post #4 of 7 Old 03-25-2014, 04:42 PM
LumpyGrits
Tell'em, that you want to 'pull' from the stop light on........
You will want to maintain near stock manifold vacuum at idle, for brakes etc.
Good luck,
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #5 of 7 Old 03-25-2014, 10:52 PM
RenoF250
Crower will recommend a cam as well. I filled it in a Dave Crower answered about 3 hours later on a Sunday. I ended up getting the BajaBeast for a mild cam with good low-end.
RenoF250 is offline
post #6 of 7 Old 03-26-2014, 05:02 AM
swatson454
1983 CJ7
Will this be a Gen 1 SBC with the addition of fuel injection or are we talking Vortec here?
Either way, for crawling around on the trails and general use, I'd go with either the Comp XE 256 or Lunati Voodoo 256. They'll both work just fine with exhaust manifolds and any kind of fuel injection you want to run.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #7 of 7 Old 03-26-2014, 08:34 AM
duffer
1955 CJ3B
Compression ratio? Stock roller cam block? Valve size? Head type? The Comp XE 256 recommended above should give some decent bottom end, but if the CR is above 9.5 and it's a roller cam block, you could get something with more lift and still the short duration with good low end torque. Roller cam retrofits to the early Gen I blocks also work very well but those aren't cheap.
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline
cj7
