Cam Help for Ashley's 304 - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Cam Help for Ashley's 304
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 08-12-2013, 03:14 PM   #46
swatson454
1983 CJ7
Running the plunger up and down a couple of times in a bucket of oil is a good thing but I don't believe the surface tension of the oil will allow it to pass through the tiny hole in the lifter so the overnight soak deal is up for debate.
If you get the adjustable rockers and assuming your push rod length is correct, when you go to install the rockers and push rods, just spin the push rod back and forth with your fingers as you run the rocker adjustment nut down. When you feel through the push rod that it's made contact with the lifter and the rocker, consider that "zero lash". Give the adjustment nut another half turn and call it good.
After the cam has been run in for at least a half-hour at 2,000+ rpm, you can do a final adjustment of the rockers. You can remove one valve cover at a time and throw some oil stoppers on the rocker arms. They won't block the oil completely but they'll help keep the smoke down.
With the engine idling, back off the rocker arm nut until you hear it clacking. Slowly tighten it back up until it's quiet and then go another 1/4 to 1/2 turn. Personally, I'm a quarter turn kind of guy. Just go down the line from front to back. The engine usually complains a bit when you crank the nut down so be patient and let it recover. It's just the lifter preload holding the valve open for a second. It'll stabilize.
If you stay with the AMC rockers, do three Hail Mary's and a random act of kindness and hope that you guessed the right push rod length because it is what it is
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now   Reply With Quote Quick reply to this message
Unread 08-12-2013, 03:49 PM   #47
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
If memory serves, I think the lifter pre-load on a 304 should be around .050" plus or minus .020".
It's very easy to measure either with a dial-indicator, or by using the adjustable rod from Comp Cams, or by scribing marks on the rod itself.
For what it's worth, several experienced mechanics told me it was an important step that is often overlooked.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2013, 04:04 PM   #48
Rollbar
1984 CJ8
Wow thanks-didn't know that.
Jim
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote Quick reply to this message
Unread 08-12-2013, 04:19 PM   #49
Rollbar
1984 CJ8
Are those roller rockers adjustable? I looked on their site/page but it doesn't say.
http://www.compperformancegroupstore...de=A8CAMSHFTXE
Is that to break the cam in? I thought by adding the break-in oil and running the engine/driving would do that.
That's funny
Thanks,
Jim
Unread 08-12-2013, 10:30 PM   #50
Rollbar
1984 CJ8
Well Ashley is going to replace what we have been talking about
She asked about replacing her cam bearing since she is putting the $ into the motor. I have to call the machine shop.
Do I have to remove the pistons so they can install the Cam bearings, or how do they do that on the v8?
Sorry, never been that deep in the bottom end.
Question, do they need to mic the cam bearing journal/where they go before she buys them?
I tried finding them on their site http://www.compcams.com but came up empty-guess I have to call again.
Thanks,
Jim
Unread 08-12-2013, 10:40 PM   #51
Rollbar
1984 CJ8
Without her spending to much more money, I was telling her this is the time to get rid of her old distributor (1980).
I did notice some HEI on eBay and I also told her she needed to get new cam gear/dist gear as well.
As for the coil, I mentioned the MSD but that costs to much so I was thinking of a MSD or Accell canister coil.
Can you all give me a heads up on what to do/what would work.
Thanks,
Jim
Unread 08-12-2013, 11:03 PM   #52
Rollbar
1984 CJ8
Also, does Ashley have to buy certain dist springs w/this cam/setup?
Unread 08-12-2013, 11:55 PM   #53
Matt1981CJ7
1981 CJ7
Is there anything wrong with her original distributer? If not, the "Team Rush" upgrade would be cheaper than swapping in an HEI. Google it.
You can customize the advance curve on her original dizzy, as well, but you'll need the engine running to do it. That's a fine-tuning thing.
Matt
Unread 08-13-2013, 01:12 AM   #54
Rollbar
1984 CJ8
Original Dizzy ok.
Can I buy a Cam/Dist gear to match for her OEM?
Unread 08-13-2013, 07:13 AM   #55
petey156
1977 CJ5
If I were in your position. I would take the block to the machine shop. Allow the to install the new cam bearings. While it is there have them check the bearing clearances. You don't want a lot of money is this and then have problems..
petey156 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2013, 07:25 AM   #56
roboto65
1976 CJ5
http://www.summitracing.com/search/m...e/cam-bearings
http://www.summitracing.com/search?S...m%20gear&dds=1
Hope that works and yeah replace as a set and the cam bearings are press fit and should be checked by the machine shop and when you get it back make SURE to check the bearings for the cam as if the oil hole is not lined up it will make short work of cam and the bearings and then the other parts.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2013, 07:54 AM   #57
lucdog
lucdog's Avatar
1980 CJ5
Jim, I have a 304 (154K miles)with a Davis Unifed Ignition HEI distributor, and their Proprietary plug wires.
Another with a 304,( 85k miles) TeamRush, factory ignition box, and a Ford E-core coil, the factory distributor, with wires from NAPA. Both of these are stock engines with a 2bbl carb.
Also a 360 ( 1971 with unkown miles)that has the factory distributor, Stealth HEI, and the TeamRush. This one now has a MSD 6, the same distributor, and the same coil. This one also has cut to fit MSD wires. This one also has a Edlebrock intake with a Quadrajet. But is otherwise stock.
In all honestly I don't fell any seat of the pants difference between the 3. They are also geared Appropriately for the tire size.
All 3 use the factory cast exhaust manifolds.
The advantage of the HEI distributor is the ease of install, it's just 1 wire.
IMO, I would run the Stealth HEI, ( this is basically the GM ignition module in the Motorcraft box) the big cap and adapter with quality plug wires (teamrush) on the Factory distributor. And the Ford E-core coil. I feel this will be the best bang for the $. Then tune the advance curve like Matt said.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
Unread 08-13-2013, 08:15 AM   #58
Matt1981CJ7
1981 CJ7
Originally Posted by Rollbar View Post
Original Dizzy ok.
Unless they show excessive wear, you can re-use what's already there. If you go new, be sure to buy a matched set.
I agree with Pete, have a shop install the cam bearings. Papa Bill has also given some sage advise.
Matt
Unread 08-13-2013, 09:18 AM   #59
lucdog
lucdog's Avatar
1980 CJ5
Just a FYI. The cam bearings are smaller towards the rear of the engine, as are the journals on the cam. I believe this is to make a cam install easier, this may not be the only reason.
Matt, didnt you have a problem with this, or it may have been someone else.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-13-2013, 09:41 AM   #60
Matt1981CJ7
1981 CJ7
Bill,
It must have been someone else. My cam install went smoothly.
One tip on installing the cam is to stick some kind of "handle" into the snout of the cam. I think I used a piece of all-thread. This will prevent gouging one of the bearings as you slide the cam in.
Also, care must be taken when installing the cam gear, so that you don't knock the rear cam plug out.
Matt
