Cam Help for Ashley's 304 - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Cam Help for Ashley's 304
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 09-01-2013, 11:05 AM   #136
Rollbar
1984 CJ8
Originally Posted by roboto65 View Post
That Mallory is no good ship it to me and I will dispose of it properly it is dual points so if you like points thats your call electronic better IMHO but points work.
If it is a points dizzy - make offer and I will see if he wants to get rid of it.
I wonder though if it can be converted to a electronic dizzy - would be better than a stock one, maybe ??
Thanks,
Jim
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 05:02 PM   #137
Rollbar
1984 CJ8
OK going to order these - http://www.summitracing.com/parts/crn-99730-2
And the Cam Kit - http://www.summitracing.com/parts/cca-k10-214-5
Can she use this break-in oil ? http://www.summitracing.com/parts/cca-1590
About to pull the trigger on the total purchase later today.
Unread 09-01-2013, 10:54 PM   #138
Rollbar
1984 CJ8
OK she pulled the trigger and bought the Cam kit
Happy, happy, happy.
Will update-Thanks to everyone, who helped both of us.
P.S. Push Rod checker on the way - might need help w/that to make sure she does it right.
Thanks,
Jim
Unread 09-02-2013, 09:13 AM   #139
swatson454
1983 CJ7
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote Quick reply to this message
Unread 09-02-2013, 11:52 AM   #140
Rollbar
1984 CJ8
Her Cam/Dist gear isn't that worn but ............
Are these good from Summit ?
Not sure she should MIX the two. Bulltear has a matching set for 130 bucks + shipping $$$
Any suggestions ?
Thanks,
Jim
Summit Dist gear:
http://www.summitracing.com/parts/sum-850048-12
MSD Cam gear:
http://www.summitracing.com/parts/msd-8007
Unread 09-03-2013, 04:20 PM   #141
bradleybrb
1975 CJ5
Got any pics of the original set Jim? If they are the factory set or the set you have been running on it and still look good, I would be tempted to put them back in there since you have been running them before with out problems. That cam/dist. gear thing gives me the hibby jibbys about mixing them. I have heard too many stories about them getting chewed up.
bradleybrb is offline   Reply With Quote Quick reply to this message
Unread 09-03-2013, 05:20 PM   #142
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Jim,
I'd either re-use the original set, if it's in good shape, or buy the matching set from Bulltear.
Good luck,
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
Unread 09-03-2013, 08:05 PM   #143
Rollbar
1984 CJ8
Ok thanks-looks pretty good just a few shiny spots but not really worn like most you see. We will probably use the original cam/dist gear.
As for rockers:
I'm sure some have wear on them from looking at the engines caked on oil.
I told her she might want to consider using B-Tears rocker arms, BUT, the ones he sells has a hole of .008" UNDER STOCK (whatever that means) to IMPROVE oiling.
http://www.bulltear.com/catalog/prod...5r01lckjgc6jc4
Now, to improve oiling, doesn't she need the push rods that match HIS system/product ? And as of yet, she is not sure of the push rod length.
We were talking, and she wants to just get this over with/buy whatever won't break I told her I would ask you guy's on this recent topic.
Again, 1K thanks on helping us,
Jim
Unread 09-03-2013, 09:43 PM   #144
Rollbar
1984 CJ8
Question-are the distributors the same length etc for a 258 as well as a 304/360 ?
Reason I ask is I might have both and will convert one to prime both motors before start up.
Thanks,
Jim
Unread 09-03-2013, 10:48 PM   #145
Matt1981CJ7
1981 CJ7
Thanks,
Jim
Umm, I'm not sure. But, if you have both of them, why don't you compare them and see for yourself?
Good luck,
Matt
Unread 09-03-2013, 11:37 PM   #146
Rollbar
1984 CJ8
Good luck,
Matt
I might have both
I'll have to do some digging and see if I still have it after the major parts clean up.
If I can find the other one I will post up.
Just didn't feel like taring apart the garage again
Thanks,
Unread 09-04-2013, 11:02 AM   #147
CSP
No, the I6 and V8 aren't the same length.
CSP is offline   Reply With Quote Quick reply to this message
Unread 09-04-2013, 11:43 AM   #148
Rollbar
1984 CJ8
Awesome. Thanks.
Unread 09-11-2013, 05:41 PM   #149
Rollbar
1984 CJ8
Parts are in
Unread 09-12-2013, 06:30 PM   #150
Rollbar
1984 CJ8
We are picking up the short block tomorrow and we will run 5qts of Joe Gibbs Break-in Oil, then change it out and run some Joe Gibbs 10w30 oil in it.
Question, how long should she run the regular 10W30 JG oil? 1500 miles, 3k ?
Thanks,
Jim
