Cam Help for Ashley's 304 - Page 8 - JeepForum.com
post #106 of 204 Old 08-28-2013, 09:54 AM Thread Starter
Rollbar
1984 CJ8
Sticky !
<----Click
<---- Click
Rollbar is offline
post #107 of 204 Old 08-28-2013, 11:07 PM Thread Starter
Rollbar
1984 CJ8
OK, ashley just left and told me to order this kit from Comp Cams - then see if I can find Hesco to order push rods w/the info from C-Cams.
http://www.compperformancegroupstore...Category_Code=
http://www.compcams.com/Company/CC/c...x?csid=20&sb=2
<----Click
<---- Click
Rollbar is offline
post #108 of 204 Old 08-29-2013, 08:40 AM
swatson454
1983 CJ7
Originally Posted by Rollbar View Post
Now (haven't read article yet from Comp Cams), does each cyl (or just one to check), have to be on TDC and both valves closed for OALength ?
Maybe a U-Tube video might help.
Thanks again guys - might as well do it right the first time cause 2k-2500 rpm upon start will surly wipe out a cam if everything is not right-am I correct?
Thanks again everyone for all the help in helping me get her Jeep back on the road.
Jim
Here's a video of how the length-checker tool is used, although the geometry stuff won't apply to your AMC.
You only have to measure from one lifter. If you want to measure from an intake lifter, rotate the engine around until the exhaust lifter from that cylinder starts to move up. If you want to measure from the exhaust lifter, rotate the engine until the intake lifter from the same cylinder is almost back down completely. That method will make sure that the lifter that you're measuring from is on the base circle of the cam.
Hopefully that will help make sense of the method I was discussing with Matt earlier.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #109 of 204 Old 08-29-2013, 09:25 AM Thread Starter
Rollbar
1984 CJ8
Wow-Thanks Shawn.
We are going to order the kit install and then a push rod checker - best way to go.
Then we/I want to order some push rods tat aren't 133 bucks for the set, but want hardened ones.
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #110 of 204 Old 08-29-2013, 09:50 AM
swatson454
1983 CJ7
Let me know if you get lucky and need 7.800 on the length. I've got a set of custom Trick Flows here that are hardened, one-piece, .080 wall-thickness I could probably be squeezed for only shipping. They've got a few hours of run time on them and probably 10 dyno pulls.
Shawn
post #111 of 204 Old 08-29-2013, 10:37 AM Thread Starter
Rollbar
1984 CJ8
Shawn
I will-thanks-but if so we would like to offer pay something. I will let you know.
I told Ashley, she might have to put all your names on her tailgate for helping us.
<----Click
<---- Click
Rollbar is offline
post #112 of 204 Old 08-29-2013, 10:41 AM Thread Starter
Rollbar
1984 CJ8
Shawn-do you think if we order the THIRD and FOURTH one on this list from Jeg's we should be ok as far and the length to test or ....
Now , keeping in mind our current stock P-rods are 7.773
The master kit is just to expensive for this project.
<----Click
<---- Click
Rollbar is offline
post #113 of 204 Old 08-29-2013, 10:42 AM Thread Starter
Rollbar
1984 CJ8
Also-what is a good recommendation for a set of STOCK rockers?
I've seen some for 110 bucks etc. to much for this motor.
Is there a good hardened set she could buy ?
I told her it would be wise to change out the rockers due to wear from the old P-rods etc. - is that right?
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #114 of 204 Old 08-29-2013, 11:40 AM
swatson454
1983 CJ7
It sounds like you're stuck right in the middle of a 7702 or a 7703. It just can't be easy, can it
http://www.compperformancegroupstore...ngth%20checker
I'm not real sure where to go for rockers. I was going to suggest Hesco but they want a hundred and fifty bones! http://www.hesco.us/products/7735/cy...a#.Uh-Gtzash8E
Also, it would be in her best interest to not have my name anywhere on the Jeep. Between the Witness Protection and the Colombians, no good could possibly happen
Shawn
post #115 of 204 Old 08-29-2013, 12:13 PM
jumbojeepman
1976 CJ7
Sorry to jump in so late, but I was really pleased with my Crower 'Baja Beast' cam for my 304, which seems pretty identical to yours (Edlebrock 4 bbl and intake.) It idles well, sounds good, and had great throttle response all the way to where my automatic transmission shifts (in fact, I raised the shift point by 500 rpm because the engine wasn't falling on it's face. I had my heads refreshed (3 burnt valves) at the same time I did the cam install, and put in Crower springs while they were working on it.
A slight overbore doesn't require any change to cam specs because it doesn't add many cubic inches at all (like 4-8 depending on the amount of boring.) It's when you stroke a motor that the drastic changes happen.
jumbojeepman is offline
post #116 of 204 Old 08-29-2013, 03:54 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Thanks,
Jim
Hi Jim,
I used the Bulltear rockers.
The quality seemed good.
Matt
Matt1981CJ7 is offline
post #117 of 204 Old 08-29-2013, 04:17 PM Thread Starter
Rollbar
1984 CJ8
Shawn
<----Click
<---- Click
Rollbar is offline
post #118 of 204 Old 08-29-2013, 04:23 PM Thread Starter
Rollbar
1984 CJ8
Originally Posted by Matt1981CJ7 View Post
Hi Jim,
Matt
Thank you-they are expensive.
I also found these push rods ( http://www.bulltear.com/catalog/prod...n4opur544h9uk6 ) but will have to measure length.
<----Click
<---- Click
Rollbar is offline
post #119 of 204 Old 08-29-2013, 10:13 PM Thread Starter
Rollbar
1984 CJ8
Question-Do we have to degree the Cam when using this cam ?
<----Click
<---- Click
Rollbar is offline
post #120 of 204 Old 08-30-2013, 04:21 AM
roboto65
1976 CJ5
Well not really, degreeing a cam is just checking and making sure the everything is as advertised as far as opening and closing of the valves and that they are doing that on your engine. If things are off which they can be the only way to make changes is with a degreeable cam sprocket the big one. Or return the cam.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
