Cam Help for Ashley's 304 - Page 12 - JeepForum.com
post #166 of 204 Old 09-14-2013, 09:06 PM Thread Starter
Rollbar
1984 CJ8
Well, we would have had the engine together tonight.
Question do I have to remove the inner spring when checking pushrod length or is that just w/roller rockers.
<----Click
<---- Click
Rollbar is offline
post #167 of 204 Old 09-15-2013, 06:55 AM
roboto65
1976 CJ5
Well it would be better with a check spring but since you are only doing one valve me I would put it together and check with what you are going to run get your length and order the pushrods.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #168 of 204 Old 09-15-2013, 09:06 AM Thread Starter
Rollbar
1984 CJ8
OK Thanks.
<----Click
<---- Click
Rollbar is offline
post #169 of 204 Old 09-16-2013, 02:29 PM Thread Starter
Rollbar
1984 CJ8
Ashley's push rod checker tool came in today.
<----Click
<---- Click
Rollbar is offline
post #170 of 204 Old 09-16-2013, 03:13 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm curious to see what length Ashley will need.
Mine needed these. 7.750"
Matt
Matt1981CJ7 is offline
post #171 of 204 Old 09-16-2013, 03:15 PM Thread Starter
Rollbar
1984 CJ8
Did you use the same Cam/lobes/height ?
I guess I do need to measure the diameter of her push rods.
She ordered regular rockers from Melling.
<----Click
<---- Click
Rollbar is offline
post #172 of 204 Old 09-16-2013, 03:36 PM
Matt1981CJ7
1981 CJ7
I used a Lunati 250/256 cam and Bulltear rockers. I'm not sure how they compare to Ashley's.
Looking forward to the first fire.
Matt
post #173 of 204 Old 09-16-2013, 04:57 PM Thread Starter
Rollbar
1984 CJ8
Since we rebuilt the carb and then the timing will be set at TDC.
Question-When we fire it up, we might have to play w/it for a minute or two to get it going. Is that going to hurt her cam or ?
She as going to go w/the BT rockers but she decided to go w/the Melling ones from AZone.
<----Click
<---- Click
Rollbar is offline
post #174 of 204 Old 09-16-2013, 05:24 PM
Matt1981CJ7
1981 CJ7
I don't think tweaking the timing a little during break-in hurts a thing. My dyno guys did a bunch of that.
Matt
post #175 of 204 Old 09-16-2013, 06:01 PM
swatson454
1983 CJ7
Matt
I agree. You always seem to have to crank it one way or the other to get it to fire. That's normal.
My point earlier is that, once it does fire, you'd throw a light on it to make sure you had plenty of timing in the engine to keep the temp from going stupid on you. Have the light hooked up and safely out of the way. Go straight to over 2k rpm and check to see if it's at least 40 degrees and rotate the distributor accordingly.
The mistake during initial fire-up would be to idle it while you set it at 10 degrees or something.
I have an old friend that installed a numbers-matching, rebuilt 283? in a gorgeously restored '58 Corvette a year or so ago. I asked him how the initial fire-up went because he didn't build the engine.
He told me that he fired it up and simply set the idle speed and initial timing. All that was left to do was "break in the cam".
He had no idea (and I didn't have the heart to tell him) that he just killed about 90% of that cams ability to survive the first 500 miles.
You still might get lucky and need a 7.8 inch push rod. I know a guy... lol
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #176 of 204 Old 09-16-2013, 06:22 PM Thread Starter
Rollbar
1984 CJ8
Ok I got it now
Do you know where/what kind of tape I can buy to put on the H-Balancer ?
Shawn
OK cool-we will see and I will post.
Thank you all again-
<----Click
<---- Click
Rollbar is offline
post #177 of 204 Old 09-16-2013, 06:30 PM
swatson454
1983 CJ7
I'm guessing you may have seen this before but this is the most accurate way to find TDC. It will verify if the marks on your balancer are accurate or not. It got a little windy there but that's to be expected. The timing tape from Summit or even a local parts store (although they may have to order it) is only 6 or 8 bucks. If you're anywhere near Sparks, the stuff will be on the shelf at Summit.
http://www.jeepforum.com/forum/f8/fi...r-tdc-1290121/
post #178 of 204 Old 09-16-2013, 06:40 PM Thread Starter
Rollbar
1984 CJ8
Thank you-I will read the post.
<----Click
<---- Click
Rollbar is offline
post #179 of 204 Old 09-18-2013, 01:41 PM Thread Starter
Rollbar
1984 CJ8
http://www.bobistheoilguy.com
http://www.bobistheoilguy.com/forums...s.php?ubb=cfrm
<----Click
<---- Click
Rollbar is offline
post #180 of 204 Old 09-20-2013, 06:50 PM Thread Starter
Rollbar
1984 CJ8
Guys, do we have to remove the inner valve spring to break-in this Cam ?
PLEASE SAY NO !!!!!!!!!!!!
<----Click
<---- Click
Rollbar is offline
