Cam Help for Ashley's 304 - Page 10 - JeepForum.com
post #136 of 204 Old 09-01-2013, 10:05 AM Thread Starter
Rollbar
1984 CJ8
Originally Posted by roboto65 View Post
That Mallory is no good ship it to me and I will dispose of it properly it is dual points so if you like points thats your call electronic better IMHO but points work.
If it is a points dizzy - make offer and I will see if he wants to get rid of it.
I wonder though if it can be converted to a electronic dizzy - would be better than a stock one, maybe ??
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #137 of 204 Old 09-01-2013, 04:02 PM Thread Starter
Rollbar
1984 CJ8
OK going to order these - http://www.summitracing.com/parts/crn-99730-2
And the Cam Kit - http://www.summitracing.com/parts/cca-k10-214-5
Can she use this break-in oil ? http://www.summitracing.com/parts/cca-1590
About to pull the trigger on the total purchase later today.
<----Click
<---- Click
Rollbar is offline
post #138 of 204 Old 09-01-2013, 09:54 PM Thread Starter
Rollbar
1984 CJ8
OK she pulled the trigger and bought the Cam kit
Happy, happy, happy.
Will update-Thanks to everyone, who helped both of us.
P.S. Push Rod checker on the way - might need help w/that to make sure she does it right.
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #139 of 204 Old 09-02-2013, 08:13 AM
swatson454
1983 CJ7
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #140 of 204 Old 09-02-2013, 10:52 AM Thread Starter
Rollbar
1984 CJ8
Her Cam/Dist gear isn't that worn but ............
Are these good from Summit ?
Not sure she should MIX the two. Bulltear has a matching set for 130 bucks + shipping $$$
Any suggestions ?
Thanks,
Jim
Summit Dist gear:
http://www.summitracing.com/parts/sum-850048-12
MSD Cam gear:
http://www.summitracing.com/parts/msd-8007
<----Click
<---- Click
Rollbar is offline
post #141 of 204 Old 09-03-2013, 03:20 PM
bradleybrb
1975 CJ5
Got any pics of the original set Jim? If they are the factory set or the set you have been running on it and still look good, I would be tempted to put them back in there since you have been running them before with out problems. That cam/dist. gear thing gives me the hibby jibbys about mixing them. I have heard too many stories about them getting chewed up.
bradleybrb is offline
post #142 of 204 Old 09-03-2013, 04:20 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Jim,
I'd either re-use the original set, if it's in good shape, or buy the matching set from Bulltear.
Good luck,
Matt
Matt1981CJ7 is offline
post #143 of 204 Old 09-03-2013, 07:05 PM Thread Starter
Rollbar
1984 CJ8
Ok thanks-looks pretty good just a few shiny spots but not really worn like most you see. We will probably use the original cam/dist gear.
As for rockers:
I'm sure some have wear on them from looking at the engines caked on oil.
I told her she might want to consider using B-Tears rocker arms, BUT, the ones he sells has a hole of .008" UNDER STOCK (whatever that means) to IMPROVE oiling.
http://www.bulltear.com/catalog/prod...5r01lckjgc6jc4
Now, to improve oiling, doesn't she need the push rods that match HIS system/product ? And as of yet, she is not sure of the push rod length.
We were talking, and she wants to just get this over with/buy whatever won't break I told her I would ask you guy's on this recent topic.
Again, 1K thanks on helping us,
Jim
<----Click
<---- Click
Rollbar is offline
post #144 of 204 Old 09-03-2013, 08:43 PM Thread Starter
Rollbar
1984 CJ8
Question-are the distributors the same length etc for a 258 as well as a 304/360 ?
Reason I ask is I might have both and will convert one to prime both motors before start up.
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #145 of 204 Old 09-03-2013, 09:48 PM
Matt1981CJ7
1981 CJ7
Thanks,
Jim
Umm, I'm not sure. But, if you have both of them, why don't you compare them and see for yourself?
Good luck,
Matt
post #146 of 204 Old 09-03-2013, 10:37 PM Thread Starter
Rollbar
1984 CJ8
Good luck,
Matt
I might have both
I'll have to do some digging and see if I still have it after the major parts clean up.
If I can find the other one I will post up.
Just didn't feel like taring apart the garage again
Thanks,
<----Click
<---- Click
Rollbar is offline
post #147 of 204 Old 09-04-2013, 10:02 AM
CSP
No, the I6 and V8 aren't the same length.
CSP is offline
post #148 of 204 Old 09-04-2013, 10:43 AM Thread Starter
Rollbar
1984 CJ8
Awesome. Thanks.
<----Click
<---- Click
Rollbar is offline
post #149 of 204 Old 09-11-2013, 04:41 PM Thread Starter
Rollbar
1984 CJ8
Parts are in
<----Click
<---- Click
Rollbar is offline
post #150 of 204 Old 09-12-2013, 05:30 PM Thread Starter
Rollbar
1984 CJ8
We are picking up the short block tomorrow and we will run 5qts of Joe Gibbs Break-in Oil, then change it out and run some Joe Gibbs 10w30 oil in it.
Question, how long should she run the regular 10W30 JG oil? 1500 miles, 3k ?
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
