Cam gear oiling - JeepForum.com
post #1 of 7 Old 07-08-2009, 06:38 AM Thread Starter
olaf-inge
Cam gear oiling
Hi.
I put in a proform Hei and it eat up my cam gear. So new MSD gears are ordered. My qestion are : i want to mount a extra oil line that oils the gears properly. Can i just conect it to the oilpressure sender unit an use tubing up outside the timingcover on drill a hole in top of it så the oil pours down over the gears. Or will i loose al my oil pressuere then ??????
olaf-inge is offline
post #2 of 7 Old 07-08-2009, 06:49 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I would be extremely careful about tapping into the pressurized oiling system and routing unregulated oil flow to basically the "oil pan". I think you'll see an unacceptable drop in oil pressure.
BESRK is offline
post #3 of 7 Old 07-08-2009, 07:00 AM
jeepwhore
Also, oiling issues aren't the cause of your cam gear being eaten up (you can thank the crappy hardened steel gear on your HEI for that). You didn't mention what engine you've got but I assume its a V8 if you can replace the gear and not the cam. Regardless, the stock oiling system of either the V8 or I6 engine is adequate for keeping internals lubed properly. I have heard of oiling issues in the AMC V8's but not with any regularity and not when pertaining to non-racing appplications. IMO, replace the gears and don't worry about it.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4 of 7 Old 07-08-2009, 09:49 AM Thread Starter
olaf-inge
Its a amc 360 engine. I se the problem with the gears now , i have read a lot about diferent materials on the gears in this forun , to bad i didnt read it before i install my new HEI. But if i understand other writers correct so is MSD gears the way to go. Regarding the extra oiling i se now that it wil result in dropping oil pressure.
post #5 of 7 Old 07-08-2009, 11:33 AM
chainz
1976 CJ5
Yea the other two people were pretty close I do not think it is an oiling issue at all the gear on the cam is not as hard as the gear on the distributor this happens to any engine when you upgrade the distributor not just AMC's.
chainz is offline
post #6 of 7 Old 07-08-2009, 12:25 PM
dwloop
1976 CJ5
Just one note, be sure and check your cam sprocket oil passage is open when you replace that cam gear. If it has flash in it, or is mis-aligned it will starve the gear as well... Just search for it, it has been discussed at length.
HTH
Dave
dwloop is offline
post #7 of 7 Old 07-08-2009, 04:27 PM Thread Starter
olaf-inge
Thanks folks .-). I have checked the passages , and its okey. I run Edelbrock chain and it seems to be working nice. So now i just have to wait on my new MSD gears to arrive :-)
AMC 360 oiling mod (JunkYard Genious help needed) twmattox Jeep CJ Forum 18 11-04-2013 04:48 PM
Finally found the info - AMC V8 oiling kit Bockwinkle Jeep CJ Forum 3 09-17-2007 04:56 PM
AMC 360 Oiling problems spk454 Jeep CJ Forum 1 08-27-2007 11:45 AM
Speedometer gear after gear change rcsutton Jeep CJ Forum 9 01-26-2005 01:32 PM
AMC V-8 cam and gear oiling fuzz401 Jeep CJ Forum 2 02-19-2004 07:04 AM
