California 4.0 OBDII Swap - Page 4 - JeepForum.com
post #46 of 239 Old 07-16-2013, 09:19 PM
Skerr
Originally Posted by SLO_Ken View Post
Yup, it was that simple!
I switched the wire, and it fired right up!
I'm getting some popping off idle. Not sure if it's due to running with no exhaust, or if the timing is off, or if it's something else...
As you know, timing would be related to the crank and cam sensor. If you got the crank sensor right I doubt you have a timing issue. Probably just the open header.
Kerrdog
Go Fish! <*////><
Skerr is online now
post #47 of 239 Old 07-16-2013, 09:51 PM Thread Starter
SLO_Ken
Originally Posted by Skerr View Post
Ken, do you know where/how to plumb to the block for mechanical oil and water gauges?? Can't see where it would happen, and I prefer mech over electric.
I've got my mechanical oil pressure gauge plumbed to a "T" coming off the stock pressure sensor port.
I do not have any experience with mechanical temp sensors/gauges.
SLO_Ken is offline
post #48 of 239 Old 07-17-2013, 04:45 AM
Skerr
The mod you did for the temp sensor in the head... that's for an electric gauge, right? Not for engine controls? How much clearance (how deep) is that hole? Thanks for the pic on the oil sensor.
Kerrdog
Go Fish! <*////><
Skerr is online now
post #49 of 239 Old 07-17-2013, 09:03 AM Thread Starter
SLO_Ken
That's correct, it's for the stock CJ temp gauge sending unit. It's about 1" deep.
SLO_Ken is offline
post #50 of 239 Old 07-23-2013, 09:56 PM Thread Starter
SLO_Ken
I've been looking for a connector for the VSS. Finally found one at Napa.
http://www.napaonline.com/Catalog/Ca...165_0335244848
SLO_Ken is offline
post #51 of 239 Old 08-08-2013, 04:06 PM
Skerr
So?? Where are we??
Kerrdog
Go Fish! <*////><
Skerr is online now
post #52 of 239 Old 08-08-2013, 04:52 PM Thread Starter
SLO_Ken
I called the exhaust shop last week. They said they were swamped at the moment, and to call back in two weeks...
In the meantime, I've cleaned up and sold my old Howell TBI, and an old Weber 38/38 I had to recoup some of the cost of the swap.
SLO_Ken is offline
post #53 of 239 Old 08-14-2013, 07:30 PM Thread Starter
SLO_Ken
Well, I scabbed my old exhaust back on, just so I could do some troubleshooting without earplugs. With the exhaust back on, I am still getting severe popping/backfire as soon as I touch the gas. It's so bad, it won't rev past 1500.
I did some research and found that a faulty TPS may cause this behavior, so I checked it out. Mine checks out good, smooth transition from ~.75V at closed to ~4.8V WOT.
While researching, I realized I hadn't verified the fuel pressure at the fuel rail. So, I went down to AZ and borrowed their fuel pressure test kit. I hooked up the fuel pressure gauge to the schrader valve on the rail and started the engine. 110psi!!! I thought the WJ fuel filter (Wix 33750) was supposed to cut that back to 49 or so?
So, I need to figure out how to get the pressure down. Either a different regulating filter, a standalone regulator, or maybe I can make an earlier XJ fuel rail (with integrated FPR) work.
SLO_Ken is offline
post #54 of 239 Old 08-16-2013, 10:24 PM Thread Starter
SLO_Ken
Well, it turns out that my return line was pinched on top of the gas tank. Had to drop the tank to re-route the return line. With the line clear, I'm still getting ~60psi at the rail...
and still popping...
SLO_Ken is offline
post #55 of 239 Old 08-17-2013, 05:50 AM
gmakra
Can you may want to look at putting on a earlier fuel rail that has a vacuum pull off on the fuel regulator. This should help with your high pressure on your fuel rail I know that later model jeeps had the fuel pressure regulator in the tank.
gmakra is offline
post #56 of 239 Old 08-17-2013, 09:12 AM Thread Starter
SLO_Ken
yeah, I thought about that. The earlier rails/regulators are setup for ~35psi. The later setup needs 49psi.
Also, I think it may have something to do with the fact that I am using an aftermarket E2000-type external fuel pump (~120 psi?). If the stock in-tank pump with which the WJ filter/regulator is meant to be used puts out significantly less pressure (~75psi??), then my regulated pressure using the aftermarket pump would be higher than required, which is what I'm seeing. So maybe switching to an earlier rail/regulator would net the lower pressure I'm looking for.
Or am I not understanding how pressure regulators work?
SLO_Ken is offline
post #57 of 239 Old 08-17-2013, 03:55 PM
Skerr
Ida know, Ken. Gut told me there was something "amiss" with the WJ filter concept. I had bought one also when I was going OBDII. But I changed it all to OBDI for the greater ease of connecting everything. I am using the earlier model fuel rail. The fuel pressure reg is ridiculously expensive (for what it does)! I have read that it doesn't make a significant amount of difference about a few pounds of fuel pressure, so I would maybe not be too worried about that.
Why couldn't/wouldn't a ball valve on a return line work for pressure regulation? It works very well in irrigation. Seems like all you have to do is attach a ball/gate valve on the return line and adjust the amount of return to the tank. More return = less fuel rail pressure.
Kerrdog
Go Fish! <*////><
Skerr is online now
post #58 of 239 Old 08-17-2013, 04:14 PM Thread Starter
SLO_Ken
Yeah, I was really concerned when I saw over 100psi. 60 is still high, but I don't think it should have as much negative effect as I'm seeing. I guess my next step is to get a code reader so I can see exactly what the computer thinks is wrong...
SLO_Ken is offline
post #59 of 239 Old 08-18-2013, 07:34 PM
Skerr
Well, 60 might be too high, and you could be flooding your cylinders with too much fuel. More pressure will deliver more fuel. I woud get it down to ~35ish...
Kerrdog
Go Fish! <*////><
Skerr is online now
post #60 of 239 Old 08-19-2013, 09:06 AM Thread Starter
SLO_Ken
The later MPFI system is designed to operate around 49psi rail pressure. Yes, 60 is still too high. But it's not that much too high...
SLO_Ken is offline
