C J Heater - JeepForum.com
post #1 of 3 Old 11-05-2002, 10:58 PM Thread Starter
Crash&Burn
C J Heater
Getting ready to install the Y J body on my 79 chassic. The Y J tub did'nt have the heater however I still have the C J unit.......
I sure somebody out there has done this
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #2 of 3 Old 11-06-2002, 12:10 PM
TG CJ7
Well the heater is a direct bolt in. Some say that you will have to enlarge a hole in the tub for the fan motor plug. We didnt have to do that, ours bolted up perfectly. You will have to modify the cowl area to accept the CJ defrost duct.
This is the finished product. We measured out, from that center bolt, one foot in both directions. We then cut that section out, and replaced it with the exact same section cut out of the old CJ tub.
If you look really closely at the picture you can see where it was welded. The cowl didnt warp at all when we welded it because we used a lot of clamps, and tacked it in slowly, also the bend of the cowl itself resists warping.
Good luck
1979 CJ7 Renegade 304, 3spd, 2.5 BDS lift, Hedman headers.
Check it out
TG CJ7 is offline
post #3 of 3 Old 11-06-2002, 12:58 PM
TG CJ7
This link has a picture of the fan plug that I'm talking about.Can4x4.Com
Check it out
TG CJ7 is offline
Cj7 Heater sydneyjeep Jeep CJ Forum 6 05-04-2009 10:01 AM
Heater Hoses Minus The Heater KBONSIG Jeep CJ Forum 3 03-30-2008 07:36 AM
Heater Craft brand heater upgrade PhatBasturd Jeep CJ Forum 0 12-31-2007 08:50 AM
cj heater box in a yj Fuzz21 Jeep CJ Forum 5 02-27-2007 04:45 AM
Heater ?'s Bucket Jeep CJ Forum 7 08-27-2004 03:28 AM
