Bypass Heating Core - potential issues?! - JeepForum.com
post #1 of 8 Old 04-21-2010, 01:46 AM Thread Starter
SydneyBeast
1978 CJ7
Hi guys,
Been doing a little research on the procedure and effects of bypassing the heating core in my 1978 CJ7.
I live in a warm climate, and do not tend to use the doors or roof in my CJ, and as such have no need for the heater - I would like to remove the whole heating unit as it has little effect and would free up a bit more space under the dash.
From what I have found, this can be done by disconnecting the 2 heater coolant pipes from the back of the heater core, and connecting them together to allow for continued circulation of the coolant around the engine - this seems pretty straightforward and easy enough.
What I cannot find however, is what effects (if any) this will have in the general cooling of the engine (aside from not being able to turn the heater on if my engine started to overheat!).
Can anyone help and let me know any potential disadvantages from bypassing the heater core and whether this is going to cause any issues I haven't thought of (such as circulation problems / pressure, overheating etc.)?
Cheers in advance!
Rich
SydneyBeast is offline
post #2 of 8 Old 04-21-2010, 01:56 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
this is done in race cars all the time. couple things. your heater core does act like a mini radiator. you may see an averge temp increase of 2-5*. if you are going to bypass the heater core it is best to just cap the ports at the water pump. race guys with more years than me say do this as it eliminates the potential for a pressure loop which would affect the cooling as well. we went back on all of our race cars in the group and tossed the loops and put on caps with clamps.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #3 of 8 Old 04-21-2010, 06:59 AM
fuzz401
1978 CJ7
I would just hook the hose at the back of the intake to the water pump on the V-8 motor
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #4 of 8 Old 04-21-2010, 06:15 PM Thread Starter
SydneyBeast
1978 CJ7
Cheers guys - am a little confused though, as there seem to be a lot of conflicting reports out there...
Most things I've read indicate that you should not just cap the ports, as need to keep circulation running around the engine - any thoughts?!
(Further details - i've got the 258 (v6) engine...)
Most people who bypass their heating cores seem to do so on a temporary basis, and not seen anyone who's made it a permanent feature - hence my queries on what knock on effects it might have to the rest of the engine...
post #5 of 8 Old 04-22-2010, 09:18 AM
CSP
Why would it have any effect other than what you mentioned, turning on the heater if the engine is in an overheating situation?
Create a loop without the heater core in it and call it good. No need to overthink a simple situation.
CSP is offline
post #6 of 8 Old 04-23-2010, 01:09 AM
SparkyB
1988 FSJ Wagoneer
79 CJ5
88 Grand Wagoneer
SparkyB is offline
post #7 of 8 Old 04-23-2010, 01:18 AM Thread Starter
SydneyBeast
1978 CJ7
Originally Posted by SparkyB View Post
Apologies... my mistake (and clear lack of knowledge) showing clearly!
Am still learning and trying to teach myself as I go... just very slowly...
post #8 of 8 Old 04-23-2010, 01:58 AM
pazur
1981 CJ7
In 87-95 wrangler manual there is a coolant circulation chart for 258, 4liter, 151. it is best just stop by in an auto parts store and see for yourself.
pazur is offline
bypass , cj7 , heater core , problems
Heater Core bypass - can I do it? kharmajavah Jeep CJ Forum 14 01-24-2011 11:09 PM
Bypass heater core or just block 81cjproject Jeep CJ Forum 1 01-08-2010 12:18 PM
Heater Core bypass/intake question rebelles Jeep CJ Forum 5 08-20-2009 09:53 AM
Heater Core Issues? bohmerjr Jeep CJ Forum 18 03-01-2008 09:09 PM
ECU heating issues? ii311hive Jeep CJ Forum 5 02-02-2006 02:19 PM
