bypass fuel vapor canister? - JeepForum.com
post #1 of 6 Old 03-24-2012, 05:23 PM Thread Starter
row684
I just dropped a 360 in my 84 cj7 and looking at the fuel lines trying to figure out what to do... going with an electric because for the life of me I can't get the manual back in its hole, contacts the power steering brackets. I'm wanting to run the hose right from the pump to the filter but their is a canister on the fender that says tank, carb bowl, dist. vac., and pcv. (Fuel vapor canister??) none of my Cj's have had the canister before so should I hook it up as it says of just run it how I had planned? No emissions in this part of Utah but if its a safety issue I'll do it... Also dist. vac. already goes to the carb (holly 2bbl) so run it into a T there??
Its so much more complicated when you get older and start worrying about safety and complying with the law! lol
row684 is offline
post #2 of 6 Old 03-24-2012, 06:55 PM
texasimport
1978 CJ5
Yep, tee your disty vac line to give the canister vac signal. Then tee the PVC line which when the canister disty line gets vac signal it opens the canister PVC line allowing the purge of any vapors the third line got from you fuel bowl vent.
No more smelly garage and no performance hit.
My 78 also has a fuel tank vent that goes into the canister. But my canister is out of who knows what year jeep product and my four barrel does not have bowl vent lines to mess with.
78 304-CJ5
texasimport is offline
post #3 of 6 Old 03-26-2012, 12:11 AM Thread Starter
row684
Thanks for the advice I'll do it that way
row684 is offline
post #4 of 6 Old 03-29-2012, 08:50 PM Thread Starter
row684
The vapor canister is plumbed into the return line correct? Wait, not the return from the filter, a 2nd return line from the carb itself?
row684 is offline
post #5 of 6 Old 03-30-2012, 03:06 AM
BagusJeep
1981 CJ7
On this style of system you have a closed fuel tank. It is vented by a third fuel line that pops up in the engine bay and you connect to that to vent the tank. Connect this line to the "tank" port on the canister.
The vaccuum feed to operate the system is teed off the pipe that goes from the carb to the distributor. Connect to "dist vac".
The other lines go to whatever else in there will leak vapours.
If you have a bowl vent on the carb (and it is a big iff) connect it to "carb bowl" or blank it off.
The last connection goes to the positive crankcase ventilation system. Where you connect it depends on whether you still have the TAC air cleaner on top of the carb.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 6 Old 03-30-2012, 05:59 PM Thread Starter
row684
Ok think I got it, vacuum lines are done and there is a line to the tank already. I have an aftermarket Holley carb on it so I'm just going to plug the carb bowl line.
row684 is offline
Emissions, Fuel Vapor Storage Canister help jelmore Jeep CJ Forum 11 12-22-2010 04:05 PM
76 cj5 fuel vapor canister replacement T_TT Jeep CJ Forum 1 04-16-2010 03:56 AM
Fuel vapor canister charcol vintagecj7 Jeep CJ Forum 1 04-06-2005 03:01 PM
Fuel Vapor Canister cfvol Jeep CJ Forum 7 10-03-2004 08:39 PM
What does a Fuel Vapor storage canister do ? Later_THANKS Jeep CJ Forum 1 06-18-2004 06:38 PM
