Bypass bad starter solenoid? - JeepForum.com
post #1 of 16 Old 01-28-2009, 09:52 PM Thread Starter
SeaWulf
1983 CJ7
I believe that my starter solenoid has gone bad. Before I replace it I want to be sure its bad. The battery drains in an hour and there is a soft buzz coming from the pass side engine bay. The starter gets power, but not enough to turn over the engine, thus leading me to believe its the solenoid. (already replaced the starter)
Anyway,
Can I bypass the starter solenoid to start the engine?
SeaWulf is offline
post #2 of 16 Old 01-28-2009, 11:08 PM
JeepHammer
Running On Empty...
1973 CJ5
I'd say starter relay (solenoid) switch.
The Relay is supposed to break the connection clean when you let off the key, but if things go wrong inside.... Who knows!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #3 of 16 Old 01-29-2009, 02:36 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I use to use the old "Pliers" trick to bypass the relay but it gets exciting with sparks flying and big divots in your pliers handle.
A lot of times the battery cables have corroded to the extent they supply enough power to activate the solenoid but not enough to turn over the engine. I have to change cables evey few years on my CJ because of all the salt I play in.
You could measure the voltage across each cable to identify the bad one. (A resistance check wont work in this case unless your ohm meter uses 20 amps to measure the resistance ) or just pick up a set of new cables. 3ea.
John Strenk is offline
post #4 of 16 Old 01-29-2009, 06:52 AM Thread Starter
SeaWulf
1983 CJ7
I already tried a new battery, starter, and cables, that's why I asked about the starter solenoid.
SeaWulf is offline
post #5 of 16 Old 01-29-2009, 07:18 AM
seagrave
It does not hurt to replace the starter solenoid. I just replaces mine last night for about $10 new.
seagrave is offline
post #6 of 16 Old 01-29-2009, 07:26 AM Thread Starter
SeaWulf
1983 CJ7
Can I get a picture of the solenoid showing which two posts to short? I just want to be sure I get it right
SeaWulf is offline
post #7 of 16 Old 01-29-2009, 10:50 AM
John Strenk
1976 CJ5
Oh you can't miss it.
Just the two biggest post with the biggest cables going to them.
Just make sure your not in gear before you short them together.
post #8 of 16 Old 01-29-2009, 11:31 AM
479AZ
1978 CJ7
If you jump power from the battery side of the solenoid to the small terminal closest to the front of the vehicle that should engage the solenoid. Inside it's just an elctromagnet that closes a big contact. If you jump across both large terminals you need to use a heavy cable since it will carry the total amperage needed to spin the starter. The other way just closes the switch.
479AZ is offline
post #9 of 16 Old 01-29-2009, 05:57 PM Thread Starter
SeaWulf
1983 CJ7
thanks for the tips guys!
Unfortunately I won't have a chance to look at the jeep again for a few day.
SeaWulf is offline
post #10 of 16 Old 01-29-2009, 08:28 PM
mcurcio1989
1976 CJ7
I am not sure if you live near any auto zones but I picked up a rebuilt stater for 20 dollars after the core return. They also have a life time warranty for about ten dollars so basically I'm set for life for thirty dollars. It's almost unbelievable. I would recomend just putting a new or rebuilt starter in i tant hurt and for 20 dollars its almost not worth the time of trying to verify that it is the starter. Just a thought. . .
mcurcio1989 is offline
post #11 of 16 Old 01-29-2009, 09:11 PM Thread Starter
SeaWulf
1983 CJ7
First thing I did along with a new battery and cables.
SeaWulf is offline
post #12 of 16 Old 03-03-2012, 08:22 PM
klr650
[QUOTE=SeaWulf;6464095]First thing I did along with a new battery and cables.[/QUO
sounds like it could be the voltage regulator check on that
klr650 is offline
post #13 of 16 Old 07-10-2013, 11:25 PM
Millerlite13
Really?
Ok man it's not what you think it is, really surprised no one has told you it's your alternator. Easy to check
1: get it runnin
2: disconnect the battery.
If it dies ,its the alternator. If you hear a clicking when you start it that mean the solenoid is ok and doing its job.
Millerlite13 is offline
post #14 of 16 Old 07-11-2013, 03:36 AM
BagusJeep
1981 CJ7
1: get it runnin
I think in the last 4 years he may have fixed it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #15 of 16 Old 07-11-2013, 09:43 AM
texas1al
Be careful, a bad solenoid can eat up ignition modules if it's stuck. Might be a good idea to replace it soon.
texas1al is offline
Starter or Solenoid OrangeCJ Jeep CJ Forum 10 11-24-2009 05:06 PM
Solenoid bypass - bad idea? ejpedde Jeep CJ Forum 5 07-11-2009 07:33 AM
Starter Solenoid PODNA Jeep CJ Forum 12 03-13-2008 05:05 AM
Starter or Solenoid? tony dz Jeep CJ Forum 4 10-07-2007 06:14 PM
Starter Solenoid (2) canuk01 Jeep CJ Forum 2 07-15-2003 05:41 PM
