Buying Paint This Week- - Page 2 - JeepForum.com
post #16 of 29 Old 02-27-2012, 04:25 PM Thread Starter
PROJECT 23
I know. This thing is getting to be a real pain in the azz with this paint project. I really can't go againest the wife as she is a nurse and scares the crap out of me with pictures and stats. Sometimes you have to pick your battles, but this is not one of them........
Plus with all these threads that I have been starting regarding the paint, it helps get my post count up
PROJECT 23 is offline
post #17 of 29 Old 02-28-2012, 06:18 AM
Bobs85Reny
There are a few companies that make a waterborne paint. I think sherwin williams makes one. I have no experience with it and I am not sure what type of equipment is needed to shoot it. Its something you may want to look into.
Told my girl I just had to forget her, Rather buy me a new cartburettor,
So she made tracks sayin' ths is the end now, Cars don't talk back they're just four wheeled friends now
"Queen"
Bobs85Reny is offline
post #18 of 29 Old 02-28-2012, 06:59 AM
inovermyhead2
My understanding is that waterbourne paints can't be sprayed at home. They require a spray booth. As a matter of fact, if I remember correctly, a conventional downdraft spray booth needs to have a conversion done to make the transition to waterbourne paint. I think it needs to have air nozzles blowing down on the vehicle or something like that.
1983 CJ7
350ci Chevy
SM465 Trans
Rancho 2 1/2" lift
Confer Engineering Shackles
32x11.50x15 BFG All Terrains
whoever invented Torx bolts should be shot in the face, burned then pissed on - saskcj7
inovermyhead2 is offline
post #19 of 29 Old 02-28-2012, 07:28 AM
Bobs85Reny
I don't know to much about it. I had posted for some info on it a while back because I was interested in it myself. My next question to you is if your not going to paint it because of the fumes. How are you going to handle the bodywork and primer? That stuff isn't much better but don't worry I won't tell.
"Queen"
post #20 of 29 Old 02-28-2012, 07:40 AM Thread Starter
PROJECT 23
There is minimal body work needed. I have two small dings which I bought a dent puller to assist with fixing these. Other than that the sheet metal is very solid. The original soft top snap holes on the tub and tailgate will be filled by the paint shop via welding.
The only thing I really need to worry about is removing the bed liner that I rolled on the door sills and around the outer edge of the tub. This will be rolled back on when I get Project 23 back because I like the protection and the way it looks.
So I will not be exposed to any kind of fumes during this process. I know it sounds crazy, but I guess my wife really does love me after all
post #21 of 29 Old 02-28-2012, 07:45 AM
TxJeeper20
1982 CJ5
You asked about removing bedliner ? I have some of that duplicolor spray bedliner it served its purpose when my jeep was a bruised bag of apples but I a mwanting to go with raptor liner and need to either remove all of it or remove some areas that are flakin were proper prep work wasnt done by my dad whats your call
strip it all or just areas that are flaking ? how to remove it ?
Victory Loves Preparation
1982 CJ-5 350TBI/AX-15
1989 Porsche 928 S4
2003 Honda VTX 1300R
2005 Infiniti G35
TxJeeper20 is offline
post #22 of 29 Old 02-28-2012, 07:51 AM Thread Starter
PROJECT 23
I actually did start removing the bedliner last weekend. I used a putty knife and was able to catch some spots where my prep work lacked proper technique. That and being cold out in the garage probably helped with flaking that stuff off.
By all means, I am still having a tough time with removing it so if anybody has a better method with removing this stuff, please spill the beans.
post #23 of 29 Old 02-28-2012, 07:52 AM
bobthecatkiller
Dry ice and a hammer
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #24 of 29 Old 02-28-2012, 07:53 AM
inovermyhead2
I heard somewhere that if you apply paint stripper on top of the bedliner and then lay a sheet of plastic over the top, it will eat away at the bedliner and then it can be removed by scraper. I don't know how long this process takes but it sounds feasable.
1983 CJ7
350ci Chevy
SM465 Trans
Rancho 2 1/2" lift
post #25 of 29 Old 08-11-2012, 03:29 PM
scooter71954
2016 JK Wrangler
Today I found a possible. Brush cleaner dissolves this stuff in minutes.
scooter71954 is offline
post #26 of 29 Old 08-11-2012, 06:53 PM
mminorhsd
1979 CJ7
MAACO. The local shop did my 1972 Ford F-100 6 years ago, and it still looks great. And a lot less than $1500.00
Mike
1979 CJ 7, 258 cubic inch restoration project.
mminorhsd is offline
post #27 of 29 Old 02-02-2013, 05:33 PM
kappa505
1980 CJ5
I removed my bedliner today as well as the paint from my tub and hood. I used rust oleum aircraft stripper. It was about 60 out and sunny today when I applied it. The parts of the tub that the sun was shining on evaporated the stripper pretty quickly. The shaded parts stripped much easier so after the first coat I moved the tub into the shade and re applied another thick coat. I let this sit for about 40 min. The bed liner was actually easier to remove than the paint. I used two gallons from summit which was having a sale in the stuff for like 22 dollars a gallon. Covering with plastic may work as long as the plastic does not touch the stripper as it will eat the plastic. I dissolved many sets of nitrile gloves. Took about 2 hours total with scraping.
"Nothing in the world can take the place of Persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan 'Press On' has solved and always will solve the problems of the human race." Supposedly President Coolidge
kappa505 is offline
post #28 of 29 Old 02-02-2013, 07:19 PM
timgr
1975 CJ6
Originally Posted by PROJECT 23 View Post
Whelp, I have another update regarding Project 23's paint job. The wifey pooh has been doing research on the overall painting process and she is not a happy camper. To make a long story short, she doesn't want me exposed to paint fumes even if I have a respirator and ventilation. There is no half azzing a make shift spray booth using box fans to get the air flowing.
So with this we are going to fund a paint job which will max out at $1500. So with that I have scheduled to meet with the owner of a shop about 5 minutes from my house. I have met with him in the past to get a quote, but I want to make sure I know what I'm getting for the money. I also want to see what kind of prep work I can do to keep the cost down.
So with that being said, I guess that my trip to the paint shop will not be happening.
These kinds of paint jobs can come out really good - I've done a couple of them. Look around for a one-day shop that does good work, and get the best quality paint they offer. It'll come out nice, and shooting it yourself isn't that much cheaper...
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #29 of 29 Old 02-02-2013, 09:09 PM
jayzcj5
1978 CJ5
Putting plastic over the stripper holds in the vapors from the stripper therefor allowing the stripper to better do its job. As the other post said, the part of the body that was in the sun didn't do as well. this is because the vapors evaporated quickly and the solvents did not penetrate the bedliner. Get some painters masking plastic from a autobody supply shop/site. www.tcpglobal.com is a good one, the plastic has many uses...http://www.tcpglobal.com/kustomshop/ks3m400-6.aspx
jayzcj5 is offline
Time to Paint. What color is this? Advice (Pic & paint code options) Floridazed Jeep CJ Forum 6 04-25-2011 09:33 AM
Spray Paint or Auto Paint? NCHornet Jeep CJ Forum 19 01-06-2011 08:34 PM
Going to look at a CJ this week... Marn Jeep CJ Forum 17 11-04-2009 04:46 PM
Noob Buying 79 CJ7 this week - Needs advice mr burns Jeep CJ Forum 16 09-10-2007 07:18 PM
Kept the CJ5 for a week.... woody-77 Jeep CJ Forum 32 02-26-2007 08:12 PM
