Buying an old CJ - JeepForum.com
post #1 of 9 Old 04-16-2012, 06:21 PM Thread Starter
JBW5
1980 CJ7
Buying an old CJ
Ive been looking for a CJ for quite some time now. I found one that a guy is wanting to trade for a sport quad and seeing as how I have one im trying to part with things have kind of fallin into place. What are some main things I should look at when I go look at the jeep on thursday? The white body will have to be relaced with the blue one that comes with it pictured below. Thanks for the input!
http://s1178.photobucket.com/albums/...t=e086b7df.jpg
http://s1178.photobucket.com/albums/...t=48c841eb.jpg
http://s1178.photobucket.com/albums/...t=e88e7db3.jpg
JBW5 is offline
post #2 of 9 Old 04-16-2012, 06:26 PM
Jeff88
Check and make sure the frame is solid. There will most likely be a lot of frame surface rust, but you want to look for places that there is rot.
Take a screw driver and poke around under there, and make sure to go to the very front and the very rear of the frame really good.
Of course, everything else you would do before buying any vehicle also applies.
Jeff88 is offline
post #3 of 9 Old 04-16-2012, 06:27 PM Thread Starter
JBW5
1980 CJ7
Thanks ill check the frame real good!
JBW5 is offline
post #4 of 9 Old 04-16-2012, 07:06 PM
brownbagg
1930 MK Compass
if it will crank on its own
brownbagg is offline
post #5 of 9 Old 04-16-2012, 08:11 PM
wellmax
if you can drive it down the road, of course check the steering,
other have advised you about jeep and rust!!!!!!!!!!!!!
most of these old jeeps have been rode hard and put up wet.
steering is suspect at best, but if you can not keep it out of the ditches, you could be talking more big bucks to make it road worthy.
also, be sure the transfer case works, can you shift into and out of 4x4, also check locking hubs, will they lock in and can you get them unlocked.
check oil levels in all gearboxes. jeep brakes are most times a problem, if they have been neglected.
Note to file: many old jeep have been neglected.
remember what jeep stands for:
JEEP: just empty every pocket!!!!!!
but, i have not been without one in my barn for many years.
wellmax is offline
post #6 of 9 Old 04-16-2012, 09:28 PM
johnnypac
1980 CJ7
make sure the AC is working....
johnnypac is offline
post #7 of 9 Old 04-16-2012, 09:31 PM
rodgers3
its a jeep
If you have to use the ac
I say just take the top off and screw the ac
rodgers3 is offline
post #8 of 9 Old 04-16-2012, 09:38 PM
urbikesucks
1976 CJ5
Things to look at
Rust.....! frame cracks steering, brakes, transfer case hubs.
and of course the crate 427. good luck and remember it will cost ya double what ya think to make it yours!!!! Love mine but DAMN!!!!! THIS REC VECH IS A MONEY PIT!
urbikesucks is offline
post #9 of 9 Old 04-16-2012, 09:51 PM
BagusJeep
1981 CJ7
Check it has the owner's manual and the service book is fully stamped by the main dealer.
Seruisly, that thing has been stood in a field for some time so I would haul it out of there and go over the frame and underpinnings.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
Buying a CJ5 Help!!!!!!!!!!!! lanewaddell Jeep CJ Forum 24 06-16-2011 10:46 AM
Buying a CJ7 MIAneverforget Jeep CJ Forum 0 05-19-2011 10:49 AM
Buying a 81 CJ-7 Chuckwsu_82 Jeep CJ Forum 2 11-08-2007 11:47 AM
Buying a CJ-7 tomass15 Jeep CJ Forum 2 09-10-2005 07:43 AM
buying a CJ7 ozntz Jeep CJ Forum 0 03-23-2005 02:56 PM
