Buying 258 wrist pins separate from piston - JeepForum.com
post #1 of 2 Old 12-13-2013, 04:50 PM Thread Starter
ninjakid
1987 YJ Wrangler
My attempts at google are failing me.
Has anyone ever purchased just the wrist pins anywhere or know where it could be done?
I put them off to the side in the freezer unprotected which was a mistake on my part.
Had them in the freezer for a while when I was modifying my pin press, got busy trying to get a magneto tester running and by the time I got back to the press, well apparently coffee syrup rusts metal.
Soooo I need a new set of pins.
The only thing I have found so far is a set of the same pistons and pins I have for 75 (http://www.ebay.com/itm/SEALED-POWER...7a4437&vxp=mtr) but I wanted to see if anyone here knew of some way of just buying the pins for less.
If not I'll just have to shell out the money.
Thanks.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #2 of 2 Old 12-13-2013, 05:19 PM
only in a jeep cj
Ill have to check, but I think I have a set of good used ones....meaning no rust and was just pressed out. But I know you'd rather have new or your old ones.. just an option
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
