Buy a cj7 - Page 2 - JeepForum.com
post #16 of 31 Old 02-25-2013, 06:54 PM
melancholy35
The leak is from your brake master cylinder cap, it has a rubber gasket under it. If the gasket is dry rotted it will leak like yours appears to be. . Its a cheap fix! Welcome to the cj family!
melancholy35 is offline
post #17 of 31 Old 02-25-2013, 07:03 PM
ColdSteel85
1982 CJ7
Originally Posted by alp312
Someone help me! What is this? It looks like a relay that runs to the starter and the positive terminal on the battery, but it's loose and seems like it's preventing my jeep from starting.
X2......... Yes this is the starter solenoid. Tighten up connections and see if Jeep starts. If not you can take 2 rubber handled screw drivers and place one on each screw/lead on each side of solenoid and touch the metal parts of screwdriver together. If It arcs and Jeep tries to start the solenoid is probably bad. If you change solenoid make sure you take note which lead goes where according to orientation of solenoid as hooking up wrong will cook your new solenoid and you will be headed back to the auto store.
ColdSteel85 is offline
post #18 of 31 Old 02-25-2013, 08:23 PM Thread Starter
alp312
Thanks guys. I just fixed it. New battery terminals and solenoid.
alp312 is offline
post #19 of 31 Old 02-25-2013, 08:23 PM Thread Starter
alp312
Can you give me anymore info on repairing that Master cylinder leak?
alp312 is offline
post #20 of 31 Old 02-25-2013, 08:28 PM
brownbagg
1930 MK Compass
repair master cly leak? new master cly
brownbagg is offline
post #21 of 31 Old 02-25-2013, 08:36 PM Thread Starter
alp312
Thanks bro. And I was talking about this gasket anyone mind posting pictures where it could be found? I'm new to older vehicles.
alp312 is offline
post #22 of 31 Old 02-25-2013, 08:52 PM
melancholy35
I got mine from rock auto. You might be able to find it in the help section at any major auto store. Just remove your master cylinder cap, flip it over and remove the black rubber gasket. There are two tabs on it, you will see once you flip the cap over. Take it with you to match it up. If not tomorrow night ill look at mine and get you the part number
post #23 of 31 Old 02-25-2013, 08:56 PM
melancholy35
Also take a look at the edge around the fluid chambers and make sure they are smooth.
post #24 of 31 Old 02-25-2013, 09:01 PM
melancholy35
It looks like this :
post #25 of 31 Old 02-25-2013, 09:05 PM Thread Starter
alp312
Okay cool! The jeeps at buddy's garage but ill look Wednesday. How cost he capo e off? It looked kinda weird when I saw it
alp312 is offline
post #26 of 31 Old 02-25-2013, 09:08 PM
melancholy35
I'm not sure I understand your last question
post #27 of 31 Old 02-25-2013, 09:11 PM
ColdSteel85
1982 CJ7
Make sure master cylinder is not leaking through firewall as well, could mean it needs to be replaced.
post #28 of 31 Old 02-25-2013, 09:21 PM Thread Starter
alp312
Sorry bro! Lol I was going from my phone and didnt look. All I saw for the master cylinder was a bar there wasn't an obvious cap to me.
alp312 is offline
post #29 of 31 Old 03-02-2013, 12:52 AM Thread Starter
alp312
Sooooo running into a new issue lol. Today when I started it up, e engine wasn't completely warm yet but I pulled it out tried driving and it just died. Did it like 3-4 times especially starting uphill. Any suggestions?
alp312 is offline
post #30 of 31 Old 03-02-2013, 10:37 PM
melancholy35
Fuel pump or dirty carburetor. Also to warm it up you can engage the choke by pressing the accelerator One time to the floor. After warm up, quickly press the accelerator again.
